Page 81 of 136 FirstFirst ... 31717273747576777879808182838485868788899091131 ... LastLast
Results 801 to 810 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #801
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Tical84 View Post
    Does anyone have problems with it not muting automatically while playing Sirius? It works fine withe MP3s but not with Sirius.
    This has already been disussed. I onlystop the music. We were waiting for Spidermunz's suggested enhancment for RR but it looks like its a dead duck.
    see here
    http://www.mp3car.com/vbulletin/road...evelopers.html
  2. #802
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by lambosprit View Post
    The problem with the incomming call thing is that the phone ring is pased through RR so you'd hear the phone ringing and the mp3 file.
    I belive what he after is when phone rings, plugin plays mp3 file. I think this could be done if you just add incomming call event to plugin.
  3. #803
    Low Bitrate mcfly's Avatar
    Dec 2007
    Romania
    Ok. thats more doable. I could use the SAY or TALK command in RR for that.
    Good to hear that!
    Whaaat? Should it do that !? Well then this is another thing that's not working for me, although I didn't know it should. So my phone rings, and RR pauses winamp and displays the incoming-call-skin. That's it. Without the phone ring being passed thru RR...!
    Anyway, remember that I'm very grateful for your app, the most important part it does flawlessly. That is, making/receiving calls and auto/re-connecting the phone.
  4. #804
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    from what i have read so far here , you need a incommingcall event , like onresume etc dose in rr now, this way any user can just add this cmd to thier exectbl.ini and run anycmd thing they want after it , in this case playing a mp3 file would be somthing like this
    "ONINCOMMINGCALL","PLAYSOUND;$SKINPATH$Alert.w av"
  5. #805
    Feb 2009
    Finland
    And you could also add incall event also, so users can do like boost volume during call or mute radio during call etc.
  6. #806
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    see here
    what command does your plugin currently send to rr when there is an incoming or outgoing phone call?
    couldn't we just take that command and put it in exectbl.ini and create an entry for each screen that has a different audio source and make it pause or lower volume for whatever player is being used?
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  7. #807
    Jan 2006
    if you really want a ring tone, answering the call will pause winamp, change the playlist file to whatever, and play it, ...it wont resume.
    Try using a different audio format and set it default to another player? Then those commands would work.
  8. #808
    Mar 2010
    Dont work
    Plugin is opened, the buttons are pressed, but no actions.
    *.ddl I registered. Adress of telephone from bluesoleil(305) in *.ini wrote down.
    I use under RideRunner, BM2. At pressure of the button "SMS Read" of plugin closed.
  9. #809
    Feb 2009
    Finland
    Today is best day in my BS mobilephone history, I update BS to latest version 6.4.305.0 and finally BS started to work with Logitech usb microphone.
    Lambo, could you please add incommingcall and incall events to plugin?
  10. #810
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Dartman_71 View Post
    I would if I could find out how. Can't find anything through searching. Not sure if plugins can fire events
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
