Page 82 of 134 FirstFirst ... 32727374757677787980818283848586878889909192132 ... LastLast
Results 811 to 820 of 1334
Thread: .net Bluetooth Mobilephone Plugin
  1. #811
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Toran View Post
    Dont work
    Plugin is opened, the buttons are pressed, but no actions.
    *.ddl I registered. Adress of telephone from bluesoleil(305) in *.ini wrote down.
    I use under RideRunner, BM2. At pressure of the button "SMS Read" of plugin closed.
    Not enough info. Post debug logs
  2. #812
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by lambosprit View Post
    I would if I could find out how. Can't find anything through searching. Not sure if plugins can fire events
    Just send a command with SDK.execute("your command")
    BTMP_incoming
    BTMP_incall 'although I would have thought this would be an indicator.
    Then a plugin can just respond to that event. But it would have to then not do a processcommand= 3 or 2 afterwards.
    or someone can put in their exectbl.ini a transaltion if they want it to do something
  3. #813
    lambosprit's Avatar
    Sep 2006
    UK
    Thanks enforcer.
    I have create a connected event but the ringing one is harder. At the moment the event would be called every few seconds until the call was answered. It should only be called once per call
  4. #814
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Then you would need to set a flag for each call then unset when call is finished
    then you would only send the incoming call command if the flag is not set.
    One danger would be if the flag doesn't get unset if you don't notice the call has been dropped.
  5. #815
    lambosprit's Avatar
    Sep 2006
    UK
    for those who like adventure here's a trial using events
    "ONMOBILEPHONECONNECTED"
    "ONMOBILEPHONERING"
  6. #816
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Events not work, I try this in exectbl "ONMOBILEPHONERING","MENU;MOBILECALL.skin||PLAYSOU ND;$SKINPATH$SOUNDS\RINGING.wav"
    I notice you add radiomute but it's hooked to update thing
    Also I can't get audio device settings to work.
    #Sets the device to use for phone mic
    WaveIn=AK5370
    #Sets the device to use for phone speaker
    WaveOut=SB X-Fi Audio [EC00]
    Needs little fine tuning...
  7. #817
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Dartman_71 View Post
    WaveIn=AK5370
    nice to see you read the readme. The audio device thing doesn't work because the BS sdk doesn't work. I've asked them for advice but they say I have had enough "free" support. We'll see if they come up with anything more.
    Dont know what you mean about radiomute to update thing ...whats the update thing.
    The onmobilephonering is invoked by the mobilephone_incommingcall indicator. Without that it wont do anything.
    did the onmobilephoneconnected work?
  8. #818
    Feb 2009
    Finland
    Sorry I didn't check readme.
    With update thing I ment update=10000 setting, which check incoming call status every ten seconds, update battery/signal indicators and launch mobilecall skin. so now there is 1 to 10 sec delay before mobilecall launch and radiomute activate. If I change update interval to 30 sec I have to wait 30 sec for mobilecall, even both could be doing with ONMOBILEPHONERING event without delay. Why you chain all actions to update thing?
    I didn't get onmobilephoneconnected work either.
  9. #819
    Feb 2009
    Finland
    Okay I test with mobilephone_incommingcall indicator and still doesn't work.
  10. #820
    lambosprit's Avatar
    Sep 2006
    UK
    I was just surprised that you found out about the audio device things and assumed you'd read the readme.
    Anyway the update thing will have to stay for now as getting events to work through managed and unmanaged code is beyond me for now.
    You should see a line like
    19/03/2010 21:11:11: Que Exec: True, menu.skin, "ONMOBILEPHONECONNECTED", False
    19/03/2010 21:11:11: Executing: PLAYSOUND;C:\Program Files\carputer\RideRunner\Skins\Ultimate\ringin.wav
    in the riderunner debug.txt file. Do you see that?
    Have you tried a simpler exectbl.ini line say just with the playsound bit?
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 09:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 08:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 10:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
