Page 89 of 136 FirstFirst ... 39798081828384858687888990919293949596979899 ... LastLast
Results 881 to 890 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #881
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Speedsterworld View Post
    OK, it would seem it's loading the plugin now in Windows 7 x64.
    Thanks for helping me get this working Lambosprit.
    Good to see you got it working. Can you post what you did to help others with the same issue.
  2. #882
    Jul 2009
    B.C., Canada
    Quote Originally Posted by lambosprit View Post
    I send a radiomute;on command. If you check the documentation >> radio modules folder under rr it will tell you what radio types allow this to work
    Bummer, Mitch's Sirius isn't in there. When someone calls me and I'm listing to Sirius, all they hear is the radio. If I mute before answering I can't hear them.
  3. #883
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Is there a way to control the volume of bluesoleil? When I'm on the phone I have to turn the volume up to hear properly, then when I hang up and the music resumes I get blasted. If i turn the audio players volume down to match it, then the music doesn't play loud enough when I want to crank it unless I manually go into the mixer and adjust it.
  4. #884
    Sep 2006
    Richmond, Tx: USA
    just installed the latest version and had th same issue of plugin not showing up. So I registered it manually. It started showing up in plugin manager but everytime the skin loads I get a message.. "exception occurred: BSWrapper.dll not found". Also, if on the phone screen and click on any button, I get a popup with a lot of text and complaining about the same DLL.
  5. #885
    Jan 2006
    Quote Originally Posted by bratnetwork View Post
    is there a way to control the volume of bluesoleil? When i'm on the phone i have to turn the volume up to hear properly, then when i hang up and the music resumes i get blasted. If i turn the audio players volume down to match it, then the music doesn't play loud enough when i want to crank it unless i manually go into the mixer and adjust it.
    +1
  6. #886
    May 2007
    Duarte, CA
    +1
  7. #887
    Jan 2006
    actually the problem can be partially solved with
    "mobilephone_(pick)/hangup||setvol;n"... on the buttons to pick up and hang up calls, however if the other party ends the call first, you still get blasted.
    The solution is to add the setvol;x automactically on call end.
  8. #888
    Mar 2009
    I silabs radio
    when I answer the phone
    you hear the radio?????
    What should I do
    thanks
  9. #889
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    I find event issue. when I have set AutoConnect=True but not have phone to connect, plugin send ONMOBILEPHONEDISCONNECTED event every 10 second.
    and one vote more to phone volume boost.
  10. #890
    Jul 2006
    Hi lambosprit,
    I've been working on getting your plugin running on my carpc for about 6 hours now. I'm unable to get it to register. I did not get the plugin while it was 1.14 to confirm whether it's a version change issue like the others came across.
    I know you haven't tested on x64 systems yet but hoping you might have some insight.
    29/03/2010 5:27:54 PM: Plugin Manager: Plugin Found: MobilePhone(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped].
    I've run the following from C:\Windows\Microsoft.NET\Framework\v2.0.50727:
    RegAsm.exe "C:\CarPC\Programs\RideRunner\Plugins\Mobilephone. NET\MobilePhone.dll" /tlb:MobilePhone.tlb /codebase
    as well as C:\Windows\Microsoft.NET\Framework64\v2.0.50727:
    but have had no luck yet.
    Thanks.
    Having similar issues... 1.16 does nothing, the .dll in post #875 causes the attached log, and bswrapper failed to initialize error, etc.
    Ok, I don't know what I did, but I just tried it again, and it's working! I must've installed & uninstalled 100 times!
    On a side note, how do I make my microphone mute when the plugin isn't in use, and unmute when I'm in a call? If I leave it unmuted, I get feedback at higher volumes...
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
