Any chance this will work with CDMA phones? Namely the LG VX9100 for Verizon?
I know whats happening. We designed the installer for the bmv2 skin and so it is replacing the menu.skin. I've removed the menu.skin so it wont overwrite it. New release in first post.
It has the new plugin manager stuff so using carwings in the new riderunner shows whether the plugin is loaded and its details. Should help debugging.
Made the change to MENU instead of LOAD as well.
check the bluesoleil website. If its there it will.
My blackberry is technically CDMA. I dont see why any phone with handsfree bluetooth connectivity shouldnt work with this plugin.
I got Message boxes again today saying the debug log was in use by another program. I had to quit RR and restart it. Any idea what causes this? It always happens upon resume from hibernation.
Live mp3Car Facebook Chat
its my coding skills I'm afraid. I'm using threads but they get a bit confused when writting to a file. Haven't figuired out how to queue them up so they write one at a time. If its all working fine then just set DebugLevel=3 in your [General] of your ini file. It will reduce the debug to just error stuff so should remove the problem.
I hope to fix it properly soon but ......
I'm pretty much an amateur when it comes to coding and don't know much about threads, but I think you have to define a critical section in your code around your writes to the file, and set a mutex or something to tell other threads that you want exclusive access. Not sure how you are opening and closing the log file but if different threads are writing to it, only open it when you want to write something and then close it immediately in that critical section.
Hope this gives you a clue to solve this.
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
thanks rodweb. that helped me find some stuff. JUST FOR TESTING heres a dll with the new logging. Can you try it sonic and tell me if it works.
it'll have wait until sunday but i'll test it out.
Is there any change to make text file based phonebook? My phone is not fully supported by BlueSoleil, I can make calls and answer but it does not read sim card or show dialed etc. numbers. Othervise this is best phone plugin so far![]()
