Page 90 of 136 FirstFirst ... 408081828384858687888990919293949596979899100 ... LastLast
Results 891 to 900 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #891
    Mar 2009
    Hi lambosprit,
    to me this error,
    where can I find the debug files for mobilphone
    this is debug file for riderunner
    Attached Files Attached Files
  2. #892
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    Quote Originally Posted by bratnetwork View Post
    Is there a way to control the volume of bluesoleil? When I'm on the phone I have to turn the volume up to hear properly, then when I hang up and the music resumes I get blasted. If i turn the audio players volume down to match it, then the music doesn't play loud enough when I want to crank it unless I manually go into the mixer and adjust it.
    For my setup, I've got my mixer WAVE volume pumped up near the top(75-80%), and the WINAMP volume near the bottom(25-30%). This way when the phone kicks in and pauses WINAMP, the volume of the phone(bluesoleil) comes in at a decent volume(using the WAVE channel). Overall it's comparable to the volume of the music.
    Seems to work pretty good for me. Might want to give that a try.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  3. #893
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Quote Originally Posted by swordfishunter View Post
    actually the problem can be partially solved with
    "mobilephone_(pick)/hangup||setvol;n"... on the buttons to pick up and hang up calls, however if the other party ends the call first, you still get blasted.
    The solution is to add the setvol;x automactically on call end.
    yes i thought about this option, but I do my volume control through a knob bc I have line drivers in my audio system. The problem is that if I reduce the volume of the music enough to match the phone, then when I turn my volume knob up when I want to crank my music then it will not go loud enough and I would have to then manually adjust the volume on the PC again...
    Not a huge deal, but kind of annoying because there is a big difference in volume from my phone to my music so it would have to get dropped quite a bit.
    If there is nothing in the BT software to adjust this then I will have to make it work somewhere, but if there is a volume adjustment in there and it can be turned up it would help greatly with everything.
  4. #894
    Mar 2009
    Quote Originally Posted by achillealb View Post
    Hi lambosprit,
    to me this error,
    help my
    thanks
  5. #895
    Feb 2010
    Hello,
    Has someone already managed to get his earpiece to work properly with Bluesoleil/RR ??
    I can multiple connect my phone and earpiece (Nokia BH-200) with Bluesoleil but I just can't get the mic and speaker to work at all when making a call.
    My Phone (Palm Treo Pro) doesn't support multiple BT connections simultaneously.
    I have tried multiple combinations in the Audio Settings for speaker and mic settings but then I hear nothing at all, other time I get the main music over my earpiece.
    When using Audio Transfer button, I hear sound through de mobile's speaker but don't know where it's send when I use Audio Transfer again... quite annoying.
    Someone have suggestions??
    Porto
  6. #896
    Mar 2010
    Hi all..
    I have 2 questions,
    1: when i scroll my contact list, i use the "CTRLUP and DOWN" command, how do i select the highligthed contact to be displayed in the dialboks/ direct dial when selected ?
    2: is it possible to make some quick dial buttoms, that when i press it, it will call a pre defined contact??
    /Martin
  7. #897
    Apr 2010
    Thumbs up Thanks for all the hard work!
    First off, thank you Lambo for all of your hard work!
    I don't know if this is common among the people using this plug-in but I was having an issue with an error coming up when I would try make a call. "Application failed for an unknown reason" It even said that in the log, (no extra info).
    But I think I figured it out! If you are getting this error, just disable and re-enable the mobilephone plug-in a couple of times in RideRunner.
    It worked for me... hopefully it works for you!
  8. #898
    Feb 2007
    Limassol, Cyprus, Europe
    I had the same problem, and just disabled the 2 first options under accessibility tab in the properties inside bluesoleil program. Also, disconnecting-reconnecting the phone inside roadrunner did the trick temporarily.
  9. #899
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Well Lambs i finally joined the group here , very good job ,
    only tested on 1 phone at present and only a few functions.
    Phone = Sony Erricson X1 Running windows Mobile
    so far the only problem i have is your ONDISCONNECT event , it repeats , any way of setting this so it only fires once.
    I'll report more as i test
    again thankyou , you have finally made me put this carputer in the truck , 1st time i have had anything in any car for 3 years ...
  10. #900
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by carputer1 View Post
    I'm really pleased to hear that and glad you like it so much. I've made a change so the ondisconnected event only fires once but dont want to do a release just for that. So unless its a biggy for you its done but will be released later.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
