Page 92 of 136 FirstFirst ... 42828384858687888990919293949596979899100101102 ... LastLast
Results 911 to 920 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #911
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Just tried this out. Seems to working with my motorola droid over bluetooth. I havent fully tested but will shortly
  2. #912
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Me and the Droid haven't had luck
  3. #913
    Jan 2004
    California
    Quote Originally Posted by Dougw133 View Post
    What sort of issues did you run into?
  4. #914
    May 2008
    Bend, OR
    Nooooo I was really looking into the htc droid incredible. I was really hoping the plugin worked.
  5. #915
    Constant Bitrate Spikemonkey's Avatar
    Aug 2009
    Virginia
    I don't know if it is related to the Droid stuff in any way; but, since i upgraded my CDMA Hero to 2.1, it will only see BS and the comp as an audio device. Al the sounds will come through the PC except phone calls and thee are no phone functions. Any ideas how to go about fixing this?
    You are never done installing a CarPC.
  6. #916
    Nov 2007
    PA
    BS doesn't officially support my phone. The only way it works is if I hit swap audio when answering a call. The phone doesn't show " Bluetooth " when the call comes in or is dialed even though it recognizes and says connected to ear piece and audio. Its just not automatic. But works to an extent.
  7. #917
    Jan 2004
    California
    I have had a mix bag. I agree that the Motorola Droid on 2.1 OS does work to some extent. I have had it answering calls (except i didn't have the right skin file so it was never fully tested) and i can call out (sometimes) The problem seems to be that it doesn't connect automatically. A series of unplug/plug of the bluetooth dongle and disable/enable of the bluetooth on the phone coupled with playing around with the connections has gotten it to connect properly but as soon as i put the computer in standby and walk away when i get back in the car all is lost.
    I plan to play with it some more in hopes to finding a workaround so i can have limited functionality. I would be happy with placing and recieving calls and automatic connection.
    Do continue to post your findings with the Moto Droid
  8. #918
    Low Bitrate mcfly's Avatar
    Dec 2007
    Romania
    @Lambo I don't know whether I asked this already or not, but: I can't change device type from within Bluesoleil settings. It resets to "desktop" even if I change it. I used "headset" type (before your plugin), that way I could stream music from my phone to the PC thru A2DP.
    Is this something you did on purpose in the plugin?
  9. #919
    Jan 2004
    California
    I did some searching and came across some of your other posts (that never got answered)
    Have you requested the Droid support to be added to BlueSoliel?
  10. #920
    May 2008
    Bend, OR
    We should definitely ask as more than 100 phones now run droid and 2.2 looks OMG amazing *drool*
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
