Page 93 of 136 FirstFirst ... 438384858687888990919293949596979899100101102103 ... LastLast
Results 921 to 930 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #921
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by mcfly View Post
    @Lambo I don't know whether I asked this already or not, but: I can't change device type from within Bluesoleil settings. It resets to "desktop" even if I change it. I used "headset" type (before your plugin), that way I could stream music from my phone to the PC thru A2DP.
    Is this something you did on purpose in the plugin?
    Its done on purpose. The plugin has to register itself as a type and thats desktop. If the plugin isn't running you should be able to set it to anything you want but when its run it will be reset to desktop again.
  2. #922
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    hi lambs just playing again with this, found a few things amiss.
    add entry = would be nice if it called the OSK , so we can edit the name
    delete entry = dose not seem to work
    Edit entry = would also be nice if this was working (not implemented) so far
    also the setting in the ini, for delay time , for signal.battery,and incall popup
    the setting is set for all, can we seperate , so we have 1 for batery and signal update time, and 1 for incall popup
    the siganl and battery indicator , dose not always populate, its setting the var , but ,for
    any chance of a incall volume setting in the ini, fired on accept call use's ini vol setting
    and oncall end returns to previous vol , i know i can do sonthing , in rr code , but i think if the plugin handles its cleaner
    also noticed that some labels after mobile is running for a while 10 minutes , i lose some of the labels ie.ownnumber , network, connected ,
    hope you can work these things out cheers
  3. #923
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by carputer1 View Post
    I could do this if the skin changed the custom list itself. Then I could just store the current custom list position with its name and description. I've never looked at how the osk works so if its simpler just tell me and I'll try.
    It should. It just sends a delete current custom list position to RR and then saves the custom list to the file. Maybe its a timing issue.
    The editing allows you to edit the number against a name not the name. So if you select a number from the list then change the number and click edit it should save the new number against the old name.
    I could do this. I'll just make the delay time for bat, signal etc fixed and have the incall popup user changable.
    This really depends on the phone. If the phone doesn't support the signal and battery indicator then mobilephone just sets it to 5 (my phone has this problem). When you say its not showing the 0.gif thi is a skin problem because I just set a special indicator file variable to be used for display.eg I01,340,66,120,150,"FILE;$mobilephone_photopath$"
    Do you mean set the rr volume to some preset value when in a call and set it back to previous value when finished using the SETVOL;50
    This should only happen when you lose connection and when you get connection back they should all repopulate. Each time you request the rr label I send a request to the phone so it should find the value again if the phones connected.
    hope you can work these things out cheers[/QUOTE]
  4. #924
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Thanks for the quick response Lamb's
    1 - Not sure how this is done via Plugin, Hope some of the other PI autors can chime in here
    2 - Fingers X it is a timing issue
    3 - arh ok going about this the wrong way then , i was expecting the OSK to popup to edit
    4 - could we have delay settings for both please , as the battery and signal updates far to
    much , to often , really , my rrdebug , gets very big very quickly
    5 - i see that the signal and battery setvar to 0.gif , which i do have a graphic for , so it
    should show but its not.
    6 - yep thats what i mean , take current vol ,temp save value, setvol;XXX set in in,at end
    of call reset to temp saved value
    7 - the labels do disappear on me , while is still connected
    Thanks again for the speed
  5. #925
    lambosprit's Avatar
    Sep 2006
    UK
    Just double checked this and it works fine for me. Are you sure your using the right command. Its mobilephone_delete_entry. I've noticed that pierre's new skin for carwings has an extra PB which shouldn't be there. i will drop him a PM to fix it.
  6. #926
    lambosprit's Avatar
    Sep 2006
    UK
    I really want to make the incomming call an event driven thing rather than a timer. So for instance BS instantly tells me when a call comes in but I only check for that every x seconds. Really i should react instantly too. Then the update period just becomes a battery/signal update period. Trouble is its a pig to code.
    As for the debug I've toyed with the idea of making it like RR in that you could set it to start a new log every time its started rather than add to an existing one. thoughts?
  7. #927
    Sep 2006
    Richmond, Tx: USA
    I'm not sure what's wrong but for the life of me I cannot get 1.6 version to show up in plugin manager. I've installed it many times and I've even tried to manually register it. On the flip side, I just installed 1.4 and it instantly showed up in plugin manager.
    What is the reason for that ?? Any idea?
  8. #928
    Sep 2006
    Richmond, Tx: USA
    Quote Originally Posted by ajamils View Post
    Any one ?
  9. #929
    lambosprit's Avatar
    Sep 2006
    UK
    Any one ?
    Sometimes it doesn't show up in the plugin manager because it crashed. Try checking the mobilephone debug. Just a guess but its all I got I'm afraid.
  10. #930
    Mar 2007
    Barbados
    I,ve been trying to get this plugin to work for about two weeks and it is not showing up in the plugin manager. Help please
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
