Page 94 of 136 FirstFirst ... 4484858687888990919293949596979899100101102103104 ... LastLast
Results 931 to 940 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #931
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by wired48 View Post
    I,ve been trying to get this plugin to work for about two weeks and it is not showing up in the plugin manager. Help please
    As I said above check the debug logs. Sometimes it crashes and because it's died it doesn't show in the plugin manager. Make sure the debug levels are set to 5.
  2. #932
    Mar 2007
    Barbados
    here is my debug log. When i manually register the plugin it says it was successful. the log was created after i tried to register the the plugin
    Attached Files Attached Files
  3. #933
    lambosprit's Avatar
    Sep 2006
    UK
    WOW you're the first person I've seen using the ATSM version......is this intentional? Its all old code from lucifers original plugin which I hope I haven't broken. If you did intend to use ATSM I can try to help with more debug. If you intended to use the bluetooth then you should read up on what needs to be set to make it work.
  4. #934
    Low Bitrate mcfly's Avatar
    Dec 2007
    Romania
    I'm trying to install v1.6, but it gets interrupted at registering the DLL. Regasm executes and syas "...Types registered successfully. Assembly exported to 'd:.....\MobilePhone.tlb', and the type library was registered successfully" and in the next instance installation stops with "Failed to register mobilephone.dll" error.
    Which framework do I need? Or something else...
    Plugin v1.4 worked.
    Edit: Before registering, "VC++ Redistributable not found" pops up. I choose OK to install vcredist, but nothing happens, it jumps over to regasm part. I installed vcredist 2008 manually, rerun mobilephone 1.6 setup, the same error, vcredist not found.
  5. #935
    Dec 2007
    Romania
    Temporary workaround: installed 1.14 and copied over the dll and tlb from 1.16.
    I was again looking to figure out why battery and signal aren't showing up, but the log at debug level 5 doesn't contain that info. I know the test skin shows that info, but should also the log file?
  6. #936
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    battery and signal don't show up with many phones. I've had it show up twice with both my phones (Blackberry 8330, and Motorola Milestone/Droid) - but it's not happening everytime. It's more of a problem with the phone than the plugin. This has been mentioned multiple times.
    As for the installation, can't help you there... sorry
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  7. #937
    Dec 2007
    Romania
    Yea, I know. I wouldn't blame the phone though. Centrafuse manages to show these sliders every time.
    Anyway, this is an insignificant problem, I just had some spare time to do some debugging...
    Quote Originally Posted by sargeants View Post
    Well that's been taken care now as I said earlier; now I have to make use of the new features in the skin I use (Reborn) -especially BT PAN!
  8. #938
    Jan 2005
    I know this has been brought up but I want to findout if reading contacts from the handset is a sdk issue or just not implemented yet
    Thanks,
    yonu
  9. #939
    Dec 2007
    Romania
    Quote Originally Posted by yonu View Post
    reading contacts
    I ran some AT commands thru putty, my phone (k800i) responds ok. I read battery level, and phone make/model. I didn't know the command for listing the contacts, instead I turned to RRMobile for help, and it manages to display my contacts, and the battery level correctly.
    Signal level value is always 99.99, this I admit, may be a bug in the phone (although signal displays correctly in Centrafuse), maybe it has to be queried another way.
    Battery level is replied as 0.xx meaning xx%
    As for phone model: Mobilephone.net displays make as "Sony-Ericsson" and model as "AAD"-something. I found that "K800i" is replied to AT+GMM. That "AADxxx" stuff is AT+CGMM.
    Now if I understood correctly, Lambosprit, you don't deal with AT commands directly. So I guess there's not much you can do about the phonebook functionality. Maybe you could use AT commands for the phonebook and leave the rest to the BS SDK (?)
  10. #940
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by mcfly View Post
    You understand correctly. Thats the main reason why I went for BS because all the other phone plugins required lots of work to get all the AT commands but BS has done all the work.
    Now it is possible to send AT commands so I may be able to implement contacts using AT commands. It would mean people discovering the command though and setting it somewhere.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
