Page 95 of 136 FirstFirst ... 45858687888990919293949596979899100101102103104105 ... LastLast
Results 941 to 950 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #941
    Jan 2005
    so if i may ask is the PBAP not in the SDK or just still a work in progress?
    either way how do you get contacts to display
    also would it be possible to find out why it has stopped connecthing to my phone the phone and pc seem to be seeing each other here is the contents of debug
    6/30/2010 10:12:31 PM:Info : Starting MobilePhone version: 1.16.3740.37948
    6/30/2010 10:12:31 PM:Info : Current directory: C:\Program Files\RideRunner\plugins\Mobilephone.NET
    6/30/2010 10:12:31 PMebug : Path being set to C:\Program Files\RideRunner\plugins\Mobilephone.NET;C:\Progra m Files\PC Connectivity Solution\;C:\Windows\system32;C:\Windows;C:\Window s\system32\wbem;C:\Windows\System32\WindowsPowerSh ell\v1.0;C:\Program Files\Windows Imaging;C:\Windows\system32\Wbem;C:\Program Files\IVT Corporation\BlueSoleil\Mobile
    6/30/2010 10:12:31 PM:Info : Device address: 00:23:76:EA:99:CB
    6/30/2010 10:12:31 PM:Info : Pair code:
    6/30/2010 10:12:31 PM:Info : International prefix = 0044
    6/30/2010 10:12:31 PM:Info : International shortcut prefix = +44
    6/30/2010 10:12:31 PM:Info : National prefix = 0
    6/30/2010 10:12:31 PM:Info : Using BlueSoleil for phone connection
    6/30/2010 10:12:31 PM:Info : MobileCall.skin: on
    6/30/2010 10:12:31 PM:Info : Trying to connect to phone.
    6/30/2010 10:12:33 PMebug : Updating phoneHandle to : 27176792
    6/30/2010 10:12:33 PMebug : Device handle found is: 27176792
    6/30/2010 10:12:34 PM:Error : Exception caught in waveindev: System.NullReferenceException: Object reference not set to an instance of an object.
    at Commands(Byte choice, SByte* variable)
    at MobilePhone.APIs.Commands(Char levent, String& variable)
    at MobilePhone.MobilePhone.get_waveindev()
    6/30/2010 10:12:34 PM:Error : Exception caught in waveoutdev: System.NullReferenceException: Object reference not set to an instance of an object.
    at MobilePhone.MobilePhone.get_waveoutdev()
    6/30/2010 10:12:34 PMebug : Sending ONMOBILEPHONECONNECTED event
    6/30/2010 10:12:34 PM:Info : You have succeeded in getting a remote device's handle.
  2. #942
    May 2007
    Quote Originally Posted by lambosprit View Post
    We covered this recently and its the reason for the latest release. You need to set the wavein device in your ini file so its matched to your sound card and not your silabs radio.
    Excuse me but, How I have to do that exactly?
  3. #943
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by yonu View Post
    As I understand it from BS they have coded the sdk for pbap but they wont release it for free and I wont pay for it.
    You can get contacts to display if you put them manually into the MOBILEPHONE_PC.txt file in your install directory and have a skin setup for it.
    Not sure what your last comment means. Are you saying that the phone is not connecting as the log seems to say it is.
  4. #944
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by mclaud View Post
    You need to discover the name of the sound card / mic you want to use from the control panel>sounds and audio devices >audio tab. The name to put in the ini file is EXACTLY as displayed here including spaces and capitals etc. If you want the default sound/ mic device then leave the wavein /out blank
  5. #945
    Low Bitrate mcfly's Avatar
    Dec 2007
    Romania
    Shame on them. How much is it? there's so many of us using your plugin, we could try a donation...
    If the price for the SDK is too high or noone would donate, you could ask the creators of RRmobile and Freefone- Cdrskull(? ) for help with phonebook operations using AT.
  6. #946
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by mcfly View Post
    Its not so much the how to use AT commands. Thats fairly easy. The problem is discovering what AT commands work for each phone and unless people post what they find works it can be a killer for newbies using the app. Its not so bad with this plugin because if you can't figuire it out you would only lose the phone books. With the other plugins you lost the whole lot.
  7. #947
    Dec 2007
    Romania
    Then... how could I help you? I have Sony-Ericsson K800i, K810i, K300i, LG shine, Nokia 1200 (does it have BT?! ), Nokia N95. I could run ATsniffer and dig for the ATs but I'm not quite sure what to look for. Maybe capturing what RRmobile sends the phones, would be more apropriate.
  8. #948
    lambosprit's Avatar
    Sep 2006
    UK
    All I'm interested in is the AT codes for phonebooks. I'm not promising anything though as it may take me sometime to get it to work. I've managed to send an AT command successfully using BS but nt receive the reply.
    I must stress this is not me changing my app to work on AT commands. Its only a hack to get phonebooks working. If anyone wants to use AT commands they can by setting the PhoneLink="" in mobilephone.ini. For the rest of how it works you would have to look at lucifers original thread.
  9. #949
    Jul 2010
    Aborted install ver. 1.16
    When installong version 1.16 the installation gets aborted when trying to register "mobilephone.dll". I have tried the solution described in post 77 and restart the installation but no succes.
    I am running ICOP PanelPC 8U version with WinXPe .
    J.K Nilsson
  10. #950
    Jul 2010
    Aborted installation of Version 1.15
    When installing version 1.15 the installation gets aborted when the installer tries to register MobilePhone.dll. The registration fails and the installer aborts. I have tried to manually register the .dll according to post 77 but without success.
    I am running win XPe and are clueless.
    J.K Nilsson
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
