Page 96 of 136 FirstFirst ... 468687888990919293949596979899100101102103104105106 ... LastLast
Results 951 to 960 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #951
    Jan 2005
    lambosprit
    how much did BS quote you on the SDK? I contacted them just to see what it would run and they wanted 5k.
    yonu
  2. #952
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by yonu View Post
    lambosprit
    yonu
    Same amount for me.
  3. #953
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Viggen79 View Post
    When installing version 1.15 the installation gets aborted when the installer tries to register MobilePhone.dll. The registration fails and the installer aborts. I have tried to manually register the .dll according to post 77 but without success.
    I am running win XPe and are clueless.
    J.K Nilsson
    Try uninstalling everything but keep a copy of you're ini file. Make sure the installation directory is empty then reinstall. Do you get any error message when you register the dll manually? If not how do you know it hasn't registred properly. The reason I ask is that sometimes the dll fails to start properly and people think the registrations failed. Check the log files to see if they're output and if so what's in them.
  4. #954
    Jul 2010
    Quote Originally Posted by lambosprit View Post
    I'll try, but I am not sure what ini file you mean. It might get clearer when I sit down with my PanelPC.
    The installer says that the .dll can't be registred in a dialog box and halts the installer. When klicking "Ok" in that box the dialog box cloeses and the installer aborts the installation.
    When registring the .dll manually in the comand window the registration is succesfull but I get a remark that the .dll should be "strong" to allow automatic registration or something like that.
    I'll give it another go tonight.
    J.K Nilsson
  5. #955
    Low Bitrate mcfly's Avatar
    Dec 2007
    Romania
    I posted exactly the same problem a few days ago. If you can't get around it, try what I did. You'll find that although the installer aborted, mobilephone.dll and mobilephone.tlb are already in the folder. Copy these 2; now install v1.4 and replace the 1.4 version dll and tlb with the new ones. Plugin manager now should see your plugin, and as far as I've seen it shows up as 1.6.
    Nevertheless, if you find the real solution please let me know.
  6. #956
    Jul 2010
    Ok, got it working now. Here is what I did:
    1) Download the VC++R 2008 from Microsoft.
    2) Run the installer from 1).
    3) Run the Mobilephone.net installer.
    4) Be puzled that the installer can't find any VC++ on the computer and allow the installer to install VC++.
    5) Chose to repair the VC++ installation on your computer.
    6) The mobilephone.net installer prompts you to ad buttons to to RR skin several times before it completes the installation.
    7) Now i can see the mobilephone plugin RR in the "PLUGIN MGR" in the Carwings skinn.
    Number 7 can be due the fact that I did register the mobilephone.dll earlier and didn't unregister it before trying the road with separate VC++ installer.
    Cheers.
    J.K Nilsson
  7. #957
    Dec 2007
    Romania
    I read somewhere in the version history that VC++ is no longer included in the installer to save bandwidth.
    Anyway I tried exactly the same steps, but from 4) on, nothing. It still can't find VC++, but jumps over its installation and in an instant displays "failed to register". But it doesn't matter any more, it works for me just overwriting the old one.
    My question is: has anyone made use of the new features, like PAN?
  8. #958
    Jul 2010
    Quote Originally Posted by mcfly View Post
    Not yet, my next goal is to make my Android Hero connected to Blue Soleil on my Panel PC. On my laptop it works but not on the PanelPC.
    J.k Nilsson
  9. #959
    Nov 2009
    where is the menu.txt file?
  10. #960
    lambosprit's Avatar
    Sep 2006
    UK
    I wrote it into the code specifically for a member who said he would post how he used it but he hasn't done so far. Maybe he will now.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
