Page 98 of 136 FirstFirst ... 48888990919293949596979899100101102103104105106107108 ... LastLast
Results 971 to 980 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #971
    Low Bitrate Challenged's Avatar
    Jan 2010
    I just bought a Nexus One Android phone and was disappointed by the lack of support for it inside of BlueSoleil. The Nokia N95 I was using previously seemed to work well for most everything I wanted when hooked up to my car.
    That said, I'm running Windows 7 and using the eLite Lite skin and version 2.2 of Android, and I'm able to make and receive hands-free calls from the Nexus One and the wonderful Mobilephone Plugin. I really don't recall having to do anything out of the ordinary to set it up. Honestly, there's not much else I want to really accomplish with the phone and bluetooth in the car, but I guess it would just be nice to have some more official support inside of BlueSoleil.
  2. #972
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Thanks for the post. I have left my settings on the generic phone for BS for now. Ill give the N95 a try. Do you have to "Swap Audio" manually when making or receiving a call or does the audio go right to the PC?
  3. #973
    Jan 2010
    If I pick up my phone and dial a number, the audio is automatically transferred to the car and I can speak hands free. Similarly, if someone dials my phone while I'm driving, the music in Ride Runner is paused and I can start talking to the caller without pressing anything.
  4. #974
    Jul 2010
    Quote Originally Posted by Dougw133 View Post
    Anyone who has got Android phone working, or at least some features please post what you have done. Settings, work arounds etc..
    What do you have your PC set as? Laptop/desktop/headset?
    What do you have your phone set to do in the BT settings?
    Limitations? What works and does not work?
    My Hero with Android 2.1 works with Bluesoleil in respect of connecting a Dial Up Network and copy the contactlist from the Phone. And Bluetooth audio transfer from phone works as well.
    I havn't tried with .net bluetooth plugin yet but I can confirm that Bluesoleil works, at least partly with Android.
    J.K Nilsson
  5. #975
    Nov 2007
    PA
    I can transfer audio and phone book. I cant get this plugin to connect to my phone anymore.
    On your phone what does the PC show up has? PC Headphones? Headset?
  6. #976
    Jul 2010
    Can't register
    Hello all,
    i am a newbe in this stuff, and i want to try this Mobilephone plugin but i have problems to install it.
    If i start the RoadRunner, it says in the debug.txt
    Code:
    27.07.2010 14:25:21: Plugin Manager: Plugin Found: MobilePhone(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped].
    I tried to register it manually, this is the answer:
    Code:
    >C:\Windows\Microsoft.NET\Framework\v2.0.
    50727\Regasm /codebase "C:\Programme\RideRunner\Plugins\Mobilephone.NET\MobilePh
    one.dll" /tlb:MobilePhone.tlb
    Microsoft (R) .NET Framework Assembly Registration Utility 2.0.50727.42
    Copyright (C) Microsoft Corporation 1998-2004.  All rights reserved.
    RegAsm : warning RA0000 : Registering an unsigned assembly with /codebase can ca
    use your assembly to interfere with other applications that may be installed on
    the same computer. The /codebase switch is intended to be used only with signed
    assemblies. Please give your assembly a strong name and re-register it.
    Types registered successfully
    Assembly exported to 'C:\Programme\RideRunner\Plugins\Mobilephone.NET\MobilePhon
    e.tlb', and the type library was registered successfully
    After my manual registering, comes the same thing as above.
    There is a warning, maybe is this the register problem?
    So i googled and found this: http://www.sweetpotatosoftware.com/SPSBlog/PermaLink,guid,df3f1be8-62bc-491c-935e-570ebfe53164.aspx
    What could i do here?
    And where can i find older versions of this plugin for trying?
    Thank you, and sorry for my bad english.
    PS: I use the new Release of RR (1 - July - 2010)
  7. #977
    Aug 2009
    UK
    Try pairing but not connecting any services from the phone end of things. Then let the plugin do the connection and see what happens, this seems to work for me...............well sort of. At first the person on the other end could only hear the FM tuner until I entered the name of the wavein and waveout devices in the ini and it seemed to work, but now the caller hears nothing.
    I've tried with the PC set to desktop and headset but it doesn't seem to make much difference and it always seems to reset itself back to desktop anyway. It also doesn't seem to matter what the phone's settings are as the plugin always requests phone audio and no media audio.
    Maybe that info will help you figure something out. I'm using a HTC Hero BTW.
  8. #978
    Aug 2009
    UK
    Quick update for those asking about Android phones. Just done some testing with my HTC Hero and it works fine, aside from the slight echo that the caller has (even with the realtek echo cancellation option) and the amp that I have switching itself off when I'm talking due to no signal in the line out...................but that's not the plugin's fault.
    So, who has a really good solution to echo cancellation. I'd be keen to find out what peeps are using. Maybe it's the cheap mic that I use? Anyone found a cheap full-duplex mic (I think that's the correct type)?
    Also, if Lambo is about, I have added the bluetooth 'connect' and 'disconnect' buttons to the Simplistique skin for the plugin. It's basically because I still have this problem where audio from the Silabs stutters when the plugin is connected so I disconnect the headset device when I have the radio on. They're useful buttons to have as well. If you'd like to add that updated version to the installer then let me know.
  9. #979
    Nov 2007
    PA
    It works to an extent for me. I have dial the call and swap the audio. I too have the echoes and people complain to me all the time. I am using the Andrea sounbeam from mp3 store.
  10. #980
    May 2008
    Bend, OR
    Quote Originally Posted by Wolvers View Post
    Look in the mp3car store at their microphones, the alexa one has been well received over on the dfx5 forum for their coming voice controls
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
