Page 99 of 136 FirstFirst ... 498990919293949596979899100101102103104105106107108109 ... LastLast
Results 981 to 990 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #981
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    First off its rrvoice and its out. I use it and the Microphone works fine for rrvoice. Were talking about people hearing themselves echoes from the speakers back through the mic. Thanks for the suggestions
  2. #982
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Wolvers View Post
    Also, if Lambo is about, I have added the bluetooth 'connect' and 'disconnect' buttons to the Simplistique skin for the plugin. It's basically because I still have this problem where audio from the Silabs stutters when the plugin is connected so I disconnect the headset device when I have the radio on. They're useful buttons to have as well. If you'd like to add that updated version to the installer then let me know.
    Just been on holiday thats all. If you have an updated skin then I'd be glad to add it to the installer.
    Looks like the AT commands is a dead end for the phonebooks. I can send the comands no problem but BS doesn't return the response only the error code. New version will be released soon along with a new installer to hopefully fix all the problems people have been having with it.
  3. #983
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by opelastrah View Post
    Hello all,
    i am a newbe in this stuff, and i want to try this Mobilephone plugin but i have problems to install it.
    If i start the RoadRunner, it says in the debug.txt
    Code:
    27.07.2010 14:25:21: Plugin Manager: Plugin Found: MobilePhone(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped].
    What could i do here?
    And where can i find older versions of this plugin for trying?
    You get this error sometimes if the plugn starts but then crashes for some reason. Check the debug logs with the debug level set to 5 to make sure its not crashing. Your post showing the manual registering shows its registering fine.
  4. #984
    Aug 2009
    UK
    Quote Originally Posted by lambosprit View Post
    It's just a small change to include the buttons to connect and disconnect the BT service.
    If the phonebook stuff isn't going to work what about the commands to add entries to the current phonebook?
  5. #985
    Aug 2010
    i have a prop when i start the install a box comes up saying vc++ redistributable not found click ok to install
    so i click ok then another boxs comes up saying
    error registering crogram
    and thats it can some one please help
  6. #986
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    Quote Originally Posted by mattblack View Post
    google vc++ redistributable and download it, save it in same folder as .net phone setup... install vc++ and then .net phone.. when .net complains then allow it to install vc++ but choose to repair... worked or me
    Blessed are the "cracked" for it is they who let in the light.
  7. #987
    Aug 2010
    thanks will try that now im so new to this stuff
  8. #988
    Aug 2010
    now when i start rr it come up
    you've not set up your device address propely in the ini file
    sorry but i dont know what this is do you it will a big help thanks matt
  9. #989
    Oct 2008
    Odense, Denmark
    thats the bluetooh address of your phone, it looks much like an MAC adress of a network card
    i cant remember how it is that you look up that address, can someone help ?
    now when i start rr it come up you've not set up your device address propely in the ini file sorry but i dont know what this is
    do you
    it will a big help
    thanks matt
  10. #990
    Aug 2010
    yeah i got that but dont no were to put it in the rrconfig
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
