Page 10 of 22 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 216
Thread: Foobar2000 Player Plugin
  1. #91
    Jun 2007
    St. Louis
    I'll check the fb2k version when I get back to my car, but it's the latest stable version that's downloadable from their site (installed it 2 days ago). I think I might dump out the fb2k library and then try to see if I get the same results.
  2. #92
    Jun 2007
    St. Louis
    Fb2k version I'm running is .9.6.8, I set the player back to winamp, removed fb2k, re-installed fb2k, and then re-setup RR and all seems to be working very nicely now. I must say I really like the fb2k player...winamp NEVER hit lows like that...awesome.
    When will the rrconfig be updated to reflect the full changes and preserve the ini? I like others have mentioned that when you go into RRconfig, make a change, save the settings - the fb2k settings are wiped clean (just the path is what I've noticed).
  3. #93
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by nst6563 View Post
    next release will have it fixed.
    Ride Runner RR's Myspace
  4. #94
    Jan 2008
    plugin work with CUE
    Hi Guino,
    when I use .cue file, I found the playlist can't correct display in RR, and next song can't work with cue file. anything I missed?
    Paul
  5. #95
    Jan 2008
    I found the .cue file can't work with foobar plugin, the playlist can't display correctly, is there any way make it works.
    thanks
    Paul
  6. #96
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by 6p6p6p View Post
    thanks
    Paul
    Never tested cue files. Please explain what you mean by "playlist can't display correctly".
  7. #97
    Jun 2007
    Hi.. everybody
    I love foobar2000 for riderunner very much...
    audio sound perfect..
    Thank you for guino very much...
    Can I chang foobarvis style?
    Who have vis so cool for foobar2000 Please share ...and suggest to install ..I am Asia not good Eng.
    Thank you
  8. #98
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The only visualization supported by the foobar player right now is the built-in spectrum of foobar. You can any visualization if you can figure out how to start/stop and embed it.
  9. #99
    Jun 2009
    Have the issues with this plugin been fixed, I'll be doing my CarPC in the next month, and I want to use it
  10. #100
    Low Bitrate Cycfari's Avatar
    Nov 2006
    N1 22.921 E103 54.207
    I'm planning to use foobar2000 instead of Winamp as I intend to use ASIO output for better audio quality.
    By using ASIO OUT in Foobar, the volume can still be controlled by Foobar whereas the volume control won't work in Winamp ASIO OUT.
    Will RR be able to control Foobar Volume slider instead of Wave/Master volume?
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 12-27-2014, 03:10 AM
  2. RR 04-01-09 ... Never to late.. (GET HOT FIX)
    By Blue ZX3 in forum Road Runner
    Last Post: 05-08-2009, 09:39 AM
  3. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  4. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  5. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
