Page 12 of 22 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 111 to 120 of 216
Thread: Foobar2000 Player Plugin
  1. #111
    MySQL Error
    Oct 2004
    Quote Originally Posted by Spacelord View Post
    hi guys, I installed the foobar plugin yesterday as well as updating the RR. I chose automatic foobar configuration in RR.
    Everything works fine as long as I don't choose to play another album. the new playlist is generated but the player doesn't start. Pushing play button doesn't help, it just jumps to the next song.
    I have to exit RR and start again and then the playing starts, I can jump to next track and start/stop playing.
    foobar standalone works fine. any suggestions?
    I dont know what "installed the plugin yesterday" means!
    but i do know, if u download the RR 10/5 release, and install it
    it will work for you!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #112
    Low Bitrate Spacelord's Avatar
    Oct 2006
    yeah, well... Foobar player
    Thanks.
    Dwnlding...
    will try and report. Thx!
    Car: Volvo XC60
    CarPc: intel D945CLF2, 7"-Touchscreen, RoadRunner, IGo8
    HiFi: Diabolo D19/AndrianAudio A165g,2xPolk DB10, Signat RAMbo pimped, BRAX X2000
  3. #113
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by brandensin View Post
    guino, I increase the file buffer to 10,000 but I still get sharing violation popup for certain songs... It has nothing to do with RR but I thought i ask you for a possible solution. i am using the latest foobar2000.
    Can you post a screenshot of the popup ? I haven't seen that at all -- trying to determine it's from RR or from Foobar2000
    Ride Runner RR's Myspace
  4. #114
    Oct 2006
    @mitchjs:
    Thank's once again. Update of RR did the job.
    @guino: I also get this popup occasionally. Will try to determine from which side next time.
    Also I notice delays when loading large lists of remixes, each >100MB, RR had not this problems before I switched to foobar. a foobar problem? standalone, foobar is quick.
    Car: Volvo XC60
  5. #115
    guino's Avatar
    Nov 2004
    Toronto, Canada
    What type of file are you using ? Mp3/Wma/FLAC/OGG ? some types of files have the tag processed with mediainfo.dll -- which may be slow, you can rename it out to see if works faster.
  6. #116
    Oct 2006
    Currently I'm using mp3s. The popup is coming from foobar when I press forward button in RR and it claims access denial on some other file in the folder as the one which is starting to play.
    Car: Volvo XC60
  7. #117
    Aug 2008
    same popup here ... when i disable popup in advanced options not every song is played and id3 tags aren't correctly shown at any song
  8. #118
    guino's Avatar
    Nov 2004
    Toronto, Canada
    we'll have to do some testing then.
  9. #119
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    I'm having a bit of a playlist problem using the latest RR (10/5) and the latest Foobar (0.9.6.9) and latest Com serer (0.7 alpha 6).
    I've narrowed it down to apple lossess (alac) files (.m4a), when dealing with a folder containing alac files i'm only able to add a single file at a time to the playlist. Trying to add a folder does nothing. If i'm dealing with mp3's everything works fine.
    I also tried performing the add folder action with winamp as the audio engine and everything works fine. So the problem seems to only exist with the combination of a folder full of alac files and foobar.
    Any ideas? Also, my folder structure is as follows: Music > Artist > Album
  10. #120
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I found the issue -- .m4a is not a valid extension for the Foobar player plugin -- easily fixed.
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. RR 04-01-09 ... Never to late.. (GET HOT FIX)
    By Blue ZX3 in forum Road Runner
    Last Post: 05-08-2009, 09:39 AM
  3. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  4. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  5. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
