Page 4 of 22 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 216
Thread: Foobar2000 Player Plugin
  1. #31
    May 2009
    Ladispoli, ROMA
    I will try to uninstall and reinstall all in c:\programmi\
  2. #32
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Larry49 View Post
    Ai Ai Ai loock what I have in the RR.ini
    [Weather]
    cityweather=New York,NY
    weatherunits=USA
    weatherdegress=º
    localdatacaptureinterval=0
    [Extra's]
    playerpath=c:\program files\Foobar2000\
    playerpath=c:\program files\ foobar2000\
    That last playerpath line has a SPACE in it!! (that could be the problem) -- can you post a zip with THE WHOLE rr.ini ?
    Ride Runner RR's Myspace
  3. #33
    May 2009
    Ladispoli, ROMA
    Here you are
    Attached Files Attached Files
  4. #34
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Ok, for you guys having issues.. I'd like you to run this test application (attached) so we can try to figure out what's going on...
    Please follow these steps:
    1-Copy the test application to >>RR's FOLDER<< (Where you have rr.ini)
    2-Make sure you have foobar2000 setup in rr.ini (like you'd have it to use with RR)
    3-Make sure RR is closed and Run the test application
    4-You should see your playerpath and musicpath setting at the bottom of the window -- if they're not right, then close the test application and fix your RR.INI before doing anything else (please ensure to have only ONE playerpath OR winamppath setting in rr.ini to avoid confusion).
    5-Press the "Start Foobar2000" button -- see if it starts and/or shows any errors
    6-Press the "Create control objects" button -- see if you get any errors
    7-Press the "Add Something" button -- see if you get any errors
    8-Press the play/stop/next/prev buttons -- see if they work
    9-Copy the log window and reply back with your results
    10-Press the Close and Exit buttons
    Hopefully this will help us define what problem(s) you're having and get it running,
    Guino.
  5. #35
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Great...Tester works just fine...
    One suggestion, we probably need to add/change the player settings to say playerxxxx= and if this PI could follow the hide player setting. As I cant see what rr is telling foobar b/c its hidden and no way to make it visable for testing purpuses..
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #36
    May 2009
    Ladispoli, ROMA
    It's all ok and this is my screen
  7. #37
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The code that is in the player plugin is EXACTLY the same code that is in the test application (I just copied it into the application) -- I'm puzzled as to why it is working with the test app and not with the Player Plugin. I'll make the hide option work and you guys can the see what it's doing.
  8. #38
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I've updated the first post with a new version where hideplayer=true/false works. I would appreciate any input on the problems with that version.
  9. #39
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Err... Now it works, think that there are still some quirks with it. I first tried with it visible, worked, then hide it, was still good..I have no idea... just one of those things...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #40
    guino's Avatar
    Nov 2004
    Toronto, Canada
    As long as it works, I don't care.. :P
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-09-2012, 10:46 PM
  2. RR 04-01-09 ... Never to late.. (GET HOT FIX)
    By Blue ZX3 in forum Road Runner
    Last Post: 05-08-2009, 09:39 AM
  3. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  4. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  5. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
