This is working fine here. Can you make a debug log by going to the mixer and pressing the DOWN button of the first two frequency buttons, then exit ? The code for those should be "VOL-;FREQ1/2" it would be very odd to press the down button and the slider go up. You can also try the hideplayer=false setting then "see" what's happening in the equalizer when you press the buttons.
Ride Runner RR's Myspace
I tried "VOL-;FREQ1/2" "VOL-;FREQ3/4" "VOL-;FREQ5/7" and so on but in this mode the mixer doesn't work down and up, the frequency are always in the same position but if I move the Foobar mixer it move up and down the Mixer skin . no viceversa ....
Hi Guys
When you use Foobar2000 V0967
is the visulization working?
I did register the FoobarRRDLL, and installed COM
I do have have Cover.jpg shown, but visualization is not there for me.
[Player Setup]
player=FoobarRR
playerpath=c:\program files\foobar2000\
visuname=FoobarVis
hidewinamp=true
exitmute=true
Is there anything wrong with my setting?
Thanks in advance!
@vinchan: 9.6.7 works just fine as far as I tried.
Did you read/do these steps on install (as the 1st post said):
-Open foobar2000 by itself (while RR is NOT running), and:
-BE SURE that the spectrum is visible ON THE TOOLBAR (Default) -- or visualization will not work in RR.
I also recommend trying a different skin to see if your visualization issue isn't just a skin issue.
Sorry Guino but my english is not so good and I have difficulty to understand wath you write I've tried Foobar 0.9.6.7 but have the same problem...the frequency mixer goes only up and can't return down. If I use the foobar mixer it control the miver skin to....
I found that the "PRE" close to "VOL" doesn't work....
The very first post says that the preamp does NOT work in foobar2000.
In regards to the frequencies, if they go up, they should go down.. unless there's something different about your machine setup. What OS version do you have and do you use anything like "Large Fonts" or something like that ?
EDIT:
Please do this:
-Right click on the Desktop and select "Properties"
-Go into the "Settings" tab and click "Advanced"
-Go into the "General" tab and select "Normal Size (96 DPI)" and hit apply and OK -- restart if you need to.
-Open your foobar2000 folder and delete foobar2000.cfg
-Open RR and try the mixer again
No guino, Foobar works all ok stand alone, don't work the mixer in RR when I use Foobar2000. If I use RR with Winamp the mixer is ok with many skins. The problem is when I use Foobar2000 with RideRunner the mixer I control in the skin doesn't work.... I am using Windows XP Pro with SP3 and the charaters are all ok with normal dpi..... I'm sorry for the time you are spending with me and I'm apreciating wath you are doing....
