Page 7 of 22 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 216
Thread: Foobar2000 Player Plugin
  1. #61
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Larry49 View Post
    No guino, Foobar works all ok stand alone, don't work the mixer in RR when I use Foobar2000. If I use RR with Winamp the mixer is ok with many skins. The problem is when I use Foobar2000 with RideRunner the mixer I control in the skin doesn't work.... I am using Windows XP Pro with SP3 and the charaters are all ok with normal dpi..... I'm sorry for the time you are spending with me and I'm apreciating wath you are doing....
    Please try deleting foobar2000.cfg and running RR again.
    Ride Runner RR's Myspace
  2. #62
    May 2009
    Ladispoli, ROMA
    I don't have foobar2000.cfg. where can I find it???
  3. #63
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you installed in the "portable" mode, it would be in the foobar2000 folder, if you installed the other way, then it would be under the user folder somewhere beneath local settings\application data\foobar2000 or something like that -- never really looked for it myself, but the problem is that the current version of this plugin doesn't seem to work if you resize the equalizer in foobar2000 -- and deleting that file restores the original size of the equalizer window.
  4. #64
    May 2009
    Ladispoli, ROMA
    Sorry but it's the same thing.... anyway I will use RR with this bug, don't worry and mny tks
  5. #65
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The new version of the plugin will take care of resizing the equalizer -- hopefully that will fix it for you.
  6. #66
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I just posted a new version which *hopefully* will fix your issue with the sliders moving up when you tried to click them down (caused by the size of the equalizer window).
  7. #67
    May 2009
    Ladispoli, ROMA
    Wonderful guino.... now is all Ok !!!!!!
    Thank you very much, you made a good work....
  8. #68
    Mar 2009
    Elite lite
    Hey,
    if you havn't noticed - making this foobar plugin you solved the asio volume control problem.. just need a few tweaks..
    i'm trying to get the foobar (asio mode) working with the the elite lite skin.
    i can only control the volume with the mixer screen by moving the winamp vol slider up aand down. the regular buttons (+ and -, at all screens) does not work. i have tryed the skineditor and foundout that the regular volume up and down use the VOL+ and VOL- codes (they don't work)
    the actual volume that does work use the WINAMPVOL code.
    i would like to know how do i change the regular + - and mute buttons to control the winamp volume and mute.
    EDIT: well i was able to change the main volume buttons and it works, using this:
    "VOL+","VOL+;Winamp"
    "VOL-","VOL-;Winamp"
    "MASTERMUTE","MUTE"
    "MUTE","PAUSE",PLAY
    "MUTE","RESUME",PAUSE
    "MUTE","PLAU",STOP
    but the mute/master mute function does not mute..
    and the 100% volume counter stands still without changing with the actual volume.
    is there any way to monitor the foobar volume through the RR ? if not, how do i make the 100% disapear ?
    there must be a way to mute the foobar..
    thanks
  9. #69
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This problem with the VOL+/- and MUTE commands is NOT related to the player.. you just need to configure RR to control the MASTER Volume in RRConfig -- or just make sure mastervolmap=0 in RR.INI
  10. #70
    Mar 2009
    i'm sorry, i don't think you understand me.
    as you can see , iby adding those lines to the exectbl.ini i had managed to get control back at the main + and - volume buttons and they control the foobar volume.
    all i wan't now is to get the mute button to mute foobar (for some reason the system reffers to it as winamp..) and posssibly get the 100% volume monitor at the top to disapear or actually move according to the foobar volume.
    how is it the you mastervol line will help doing so ? do i need to erase my changes to the exectbl.ini ? (basiclly i hae gotten the main vol + - to control the foobar volume bar and everything works - why change ?)
    thanks alot for all your help.
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-09-2012, 10:46 PM
  2. RR 04-01-09 ... Never to late.. (GET HOT FIX)
    By Blue ZX3 in forum Road Runner
    Last Post: 05-08-2009, 09:39 AM
  3. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  4. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  5. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
