There's no mute control/indication for foobar or any other player. The MUTE function is only for the MIXER (sound card), that's why I told you to set that line in RR.INI ... MUTE means KEEP your current volume but prevent any audio output, if you want the indication to go to 0% while muted, you'd not be really muting, but changing the volume itself.
You can either configure your soundcard/mixer in RR (so the mute works by muting the sound card -- NOT the player) or you remap the mute button to switch the volume of the player to 0 and then back -- this can be done using SETVOL and variables to would "mimic" a mute effect, but is not really the same thing as a real mute function doesn't change volumes and this would..
LinkBack URL
About LinkBacks
