Results 1 to 1 of 1
Thread: FMOD Player Plugin
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow FMOD Player Plugin
    FMOD Player for Ride Runner
    Description:
    This is a player plugin for Ride Runner which uses the FMOD library as the audio engine.
    This is a slightly updated version of the old FMOD player plugin (no extra features, just internal improvements to allow support for newer OS versions).
    Purpose:
    This plugin provides the choice to use FMOD with Ride Runner instead of winamp/wmp/foobar2000/iTunes.
    Requirements:
    -FMOD.DLL (included with package)
    -Ride Runner 5-1-2009 (Untested with previous versions)
    Available at: www.nisuautomotive.com
    Installation:
    -Copy FMODRR.DLL to the desired location of install and use regsvr32 to register it.
    For instance: regsvr32 FMODRR.DLL (from a command prompt)
    -Copy FMOD.DLL to the same location of FMODRR.DLL
    -In RR.INI set (make sure there's no winamppath= setting):
    player=FMODRR
    visuname=FMODVis
    Extras:
    -You can customize the Visualization of FMOD using the commands:
    "player;backcolor;Red;Green;Blue" - Set the red/green/blue colors for the back of the visualization.
    "player;barcolor;Red;Green;Blue" - Set the red/green/blue colors for the bars of the visualization.
    "player;showpeak;true" - Sets if the visualization should have peaks (true) or not (false)
    "player;peakcolor;Red;Green;Blue" - Set the red/green/blue colors for the peaks of the visualization.
    * The range of each red/green/blue color is between 0 and 255.
    Attached Files Attached Files
    Ride Runner RR's Myspace
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: Yesterday, 10:46 PM
  2. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  3. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
