Thank you! I going to play with it later today.
Printable View
New list icons are so COOL! Now it's like Skype... but better. Excellent work again, Thank's.
I don't know exactly what is causing it, but I am getting an error with the latest skype plugin from the app store. I get the error when I start clicking on different names in the list.
I still have no RRSkype debug.txt anywhere on drive C: after searching the entire drive. I set DebugLevel=5 in the skype.ini.
Here are the last few lines of the RRDebug when RR crashed:
PHP Code:
9/5/2010 11:20:54 PM: Leave Exec: False, rrskype.skin, ONCLCLICK, False
9/5/2010 11:20:54 PM: Enter Exec: False, rrskype.skin, "ONCLCLICK", False
9/5/2010 11:20:54 PM: Que Exec: True, rrskype.skin, "ONCLCLICK", False
The log file is called RRSkypeDebug.log and should be created in a folder called logs under the riderunner directory.
As for that error , i dont know. Its a riderunner error not a rrskype one, which may be being caused by the plugin but I dont know what it means so dont know what coud be causing it. Any ride runner experts know what it means or what could be causing it?
What version of rr are you running on. I'm not upto date yet. I could try it.
Edit. Just tried the latest release and I dont get the error. Not much help I know. If no expert comments on the error i'll raise a new post asking what could cause it.
I hate to say this but I found small bug :) If you are offline and start RR and go to Skype skin, you will get error in few sec "You have not authorised RideRunner to use Skype. The plugin...." This not happening when you are online.
Edit: You get error even not going to Skype skin.
Small request, own status indicator would be nice add ;)
Same issue that Dartman for me:twitch:
I'm working on it but it seems skype uses its authorisation event for not being logged in as well.
Would like to updated john error, seeing that he never did repost that he found the error. He had both the old RRVM and the new RRVehicleMaintaince PI's running at the same time, once he got rid of the old version, the issue disappeared...
thats good to hear. I was racking my brains to find out why it was happening.
I've also changed the auto app download to not put up the message box when there is no internet connection. Haven't figuired out why skype sends the sme event for diffeent things but at least it stops it happening
