Sorry, but one more small request?
When I use the TTS to send a message, and then go to send another msg, the text is still in the text area from the previous message. There is no way to clear it out.
Could, either when the TTS is called up clear the text, or possibly make a button that can send a command to RRSkype to clear the text dialog?
BTW, I am actually impressed with the TTS accuracy with it! Using dictation mode, as you know, can really be bad at times. With a lot of training for the TTS however, the text is working at about 90% accuracy. Enough, that even small errors can be sent, and the receiver will know what you are saying.
LinkBack URL
About LinkBacks
