Page 16 of 17 FirstFirst ... 67891011121314151617 LastLast
Results 151 to 160 of 161
Thread: Skype Plugin released
  1. #151
    MySQL Error
    Oct 2004
    lambosprit, i installed the plugin via installer...
    my RR wont even load the plugin..
    OS win7 x64....
    did you build this as ANYCPU? or x86?
    the installer is doing the regasm (cause i see a .tlb)
    when i do a manual regasm, its full of warnings
    might be nothing... i dont know
    Type library exporter warning: Referenced type is defined in managed component,
    which is imported from a type library that could not be loaded because it was no
    t registered (type: 'SKYPE4COMLib.Call'; component: 'C:\Program Files (x86)\Ride
    Runner\Plugins\RRSkype\Interop.SKYPE4COMLib.dll').
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #152
    MySQL Error
    Oct 2004
    more info, after finding the download for skype4comm.dll and installing that into system32(syswow64)
    now the plugin registers correctly
    but RR crashes in the plugin (directory not found)
    need some better error handling there
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  3. #153
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by mitchjs View Post
    OS win7 x64....
    Never tried running it against either windows 7 or 64 bit so not surprised it doesn't work. I have dabbled in making my apps 64bit compatable but gave up as I never use it my self and seems to have a low user requirement.
  4. #154
    lambosprit's Avatar
    Sep 2006
    UK
    Does it say what directory? Did you look in the debug log? Again if its windows 7 I wouldn't be surprised if it doesn't work.
  5. #155
    MySQL Error
    Oct 2004
    no, it doesnt say which directory...
    dont blame win7 please
    and dont blame x64!!
    there is no debug log...
    so its not making it that far
    ok, i do debugging
    Could not find a part of the path 'C:\Program Files (x86)\RideRunner\Logs\RRSkypeDebug.log'
    prob TraceLogger not creating the path, before the streamwriter
    BUT id like it fixed more
    could you please fix you plugin to not violate UAC (not that i have it on)
    you are not allowed/susposed to write into the %program files% path
    please use the path supplied to you by RideRunner in the initialize method
    Public Sub Initialize(ByRef pluginDataPath As String)
    and look at the example, you need to check if the path exists for 1st run
    and create... store any USER data there, and logs
    yes, consider moveing some stuff out of your constructor, and into initialize method
    if you want some help, im here... i can help fix up, and then test in system
    the error is unrealted to win7 or x64, its just a dir dont exist when u try to create the log
    anyway... creating a LOG dir in riderunner... i now have skype
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #156
    lambosprit's Avatar
    Sep 2006
    UK
    Not blaming anything just said I wouldn't be surprised
    will do
    i now have skype
    so I'm taking it that apart from the log dir problem (which I'm going to fix) its working fine for you now?
  7. #157
    MySQL Error
    Oct 2004
    well..... it was... then RR started to crash, and it was the plugin
    so i uninstalled... when you build a new one, il try again
    you should have you installer, install and register skype4com.dll in system32, the installer if it supports x64 (and if it dont, get new installer) will put it in right place, and check its version, to make sure it doesnt overwrite newer one, and set it as a SHARED file, so its not uninstalled unless windows dll count is 0 (all handled by installer)
    ill revisit this...
    and find why it crashed, but i neeed to do work on RR, so i uninstalled
    (then forgot about it)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #158
    lambosprit's Avatar
    Sep 2006
    UK
    ill revisit this...
    This is what I've been spending most of my time on. I don't want to just install the skype4com in case it screws up the users skype, I know its not likely on a car pc but most people test on their home pc so its worth considering.
    I can get it to use the version I want by setting the dll to isolated in my .net references which keeps it separate from any other version and doesn't need to be registered.....sounds perfect right....trouble is the calling exe needs to know about the dll not just my dll. Is there anyway RR could be changed to allow this. It would have to read a manafest but other than that I'm not sure how it works.
    This is probably too complicated and I'll just have to do it through the installer but its worth a shot
  9. #159
    Jan 2006
    Dublin, Ireland
    Hi all
    I know, I know, it's a very old plugin. I'm just trying this plugin and I have a question concerning the indicator RRSKYPE_CURRUSRTYPE. I set my Skype Client on the PC to Away, but when RideRunner starts up, on the MENU.skin, where I have the RRSKYPE_CURRUSRTYPE (Reborn Skin), it initially shows the icon for PresenceOffline. If I then call up the RRSKYPE.skin, RRSKYPE-STATUS correctly shows as AWAY but RRSKYPE_CURRUSRTYPE icon then goes blank. When I go back to MENU.skin, it's blank there too
    Could it just be that the original code needs a small bit of tweaking ?
    With Win8 and Tablets, it's time for RR to make a real comeback I think.
  10. #160
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by championc View Post
    Hi all
    I use only Vista so i can't test your config !
    Can you send your MENU.skin ?
  1. Replies: 13
    Last Post: 05-28-2009, 04:18 PM
  2. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
