Plugin: On, but not Installed...
Hello,
Thanks for your work on this plugin. I've been waiting for a skype solution for a long time. I've never had any luck getting phonecontrol apps to work correctly or reliably. I've always been on some kind of a gsm winmo smartphone or on a cdma phone and timing has never worked out for me. In any case, I now also have Sprint 3G aircard and a bluetooth headset linked to the carputer.
I'm using DFX-4 with RR-1Jun09 and Skype-4. I installed RRSkype 1.3, and added the "x,RRSkype" line to plugins.txt.
When I start RR, it starts skype and logs in, but I have to minimize it manually (skype.exe /nosplash /minimized should work). I added a button to DFX that brings me to the RRSkype.skin, but the link to skype does not appear functional. (I gave RRSkype access to control skype in the skype-advanced options menu.)
If I go to the plugins viewer, it shows that RRSkype is on, but not installed.
During the installation, when it asks about where to locate the skin files, I've tried both RideRunner and RoadRunner directories, but it doesn't seam to affect where the actual plugin goes. Is there something I'm not doing during the install process? Like registering a .dll or something?
Thanks for your help.
Rob
