Page 9 of 16 FirstFirst 12345678910111213141516 LastLast
Results 81 to 90 of 158
Thread: Skype Plugin released
  1. #81
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by fdias View Post
    First of all thank you for the work you've done!
    I believe the plugin works great, but somehow it hangs my RR.
    I'm running the latest RR version with elite lite skin and the system works extremelly slow (even the button clicks are slow) until I uninstalled the RRSkype plugin.
    Anyone had this issue?
    It might do that if it either had a problem opening skype or with skype connecting to the internet. Check the log files to see what it says.
  2. #82
    Mar 2010
    Quote Originally Posted by lambosprit View Post
    Thanks for your reply lambospirit, but it turns out it wasn't RRSkype I apologize.
    I believe the problem is with TrafficCam plugin.
    Best Regards
  3. #83
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Lambo, now when you'll have radio mute code in fresh memory, could you add it to Skype plugin too, please. Also if possible, could you change play/pause so it pauses when call comes and not when you answer. Would be easier to detect when a call comes. Thank's in advance.
  4. #84
    lambosprit's Avatar
    Sep 2006
    UK
    like the one in the first post
    new version with radio muting
  5. #85
    Feb 2009
    Finland
    You little devil, you never stop to amaze me. excellent job again. Thank you very much.
  6. #86
    lambosprit's Avatar
    Sep 2006
    UK
    Ok, heres one for the brave. This is a new version of RRSkype that has speech recognition, speech to text and automatic translation.
    To use it you must install and train microsofts speech software. I can't say it enough....train...train....train....Get it here
    http://www.microsoft.com/downloads/d...displaylang=en
    How it works.
    If you receive a chat and speech is enabled it will say the person who sent the message then say the chat itself.
    If translate is enabled the the recieved messge will be checked against the skype users language and translated into your skype user language. So say you get a message in french from a french language skype user and you have english set as your skype user then it will translate the message to english and say it. It will also set you current freind to the message sender so you can reply immediately.
    For speech there are two new button commands. RRSKYPE_SPEECHON and RRSKYPE_SPEECHOFF. To use press RRSKYPE_SPEECHON. Say a chat (dont make it more than a sentance then press RRSKYPE_SPEECHOFF immediately. Dont wait for the speech to be recognised, it will be processed in the background and displayed in RRSKYPE_MSGTEXT when complete. If you dont switch it off it will continue to listen for speech and get confused If the text is ok use RRSKYPE_SENDCHAT to send it to the currently selected user.
    Now the translation is only as good as google can make it and the speech recognition is up to microsoft so if it doesn't do well in those departments for you then its not my problem otherwise I'm happy to help.
    EDIT: Removed as not working. See post 110 for fixed version to try
  7. #87
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Wow! This sounds amazing! I cant wait to give it all a go and test it all out!
    Thanks so much for all the work you have put into this!!!!
    My Fiero Build Thread
  8. #88
    lambosprit's Avatar
    Sep 2006
    UK
    thanks john. When I finally got it working its really cool...I'd be interested to know how it interacts with jebus's voicecontrol as i haven't tested that yet and it uses the same speech stuff.
  9. #89
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    I was wondering the same thing, as I dont know if they will conflict with each other or not.
    Is the incoming message also placed in a variable / lable so it can be displayed as well?
    I look forward to testing this, but I do not get back from China till the middle of the week, and have a ton of other projects and life to catch back up on first, so will probably be a couple of weeks
  10. #90
    Feb 2009
    Finland
    Click RRSKYPE_SPEECHON, don't say anything and click RRSKYPE_SPEECHOFF, RR crash.
  1. Replies: 13
    Last Post: 05-28-2009, 03:18 PM
  2. Replies: 63
    Last Post: 03-10-2009, 07:49 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
