Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: ASRR plugin: advanced support RoadRunner
    Newbie niko73's Avatar
    Aug 2007
    Bologna, Italy
    Arrow ASRR plugin: advanced support RoadRunner
    "Basically this is a multiple plugin 5 in 1, which add some new features to RoadRunnr, in detail:
    - Advanced multimedia support
    Inserting a CD/DVD or USB pendive, the plugin automatically creates a playlist and starts the audio playback, then, when the multimidia support is removed, it will be restored the previous playlist.
    - Advanced management of "Drivemon"
    Drivemon is a program created by Skynet (a member of Carputer.it forum), that allows to attenuate the volume of WinAmp when Sygic Drive gives a vocal indication.
    - Motion lock
    Lock of some screens like video, tv, dvd, etc. when the car is in movement.
    - Screen lock
    It allows to block the access to RoadRunner by typing a secret code.
    - Screen saver
    A better way to handle the screen saver with AVS and MilkDrop."
    Thanks Robby-BMW for the intro!!!
    I think it is useful to comment the config file ... paper, pen and let's go!!!
    [ASRRLicense]
    License=demo 'insert the license (default: demo - a nag screen will flash)
    [ASRRPlugin]
    ASRRAudio=on 'enable advanced multimedia support (default off)
    ASRRDrive=on 'enable advanced management of "Drivemon (SkyNet) (default off)
    ASRRMotionlock=on 'enable motion lock (default off)
    ASRRScreenlock=on 'enable screen lock (default off)
    ASRRScreensaver=on 'enable screen saver (default off)
    [ASRROption] 'start options
    [ASRROptionAudio] 'multimedia options
    OptionMute=on 'advanced support command mute (if you click on mute button the audio track go in pause...if RR is mute for a user define time, RR go in unmute and play (default off)
    OptionSkin=on 'audio or radio main skin (if RR is closed while playing an audio track, when RR start again, go in audio player skin, else go in radio player skin) (default off)
    OptionVoice=on 'enable voice support (default off)
    OptionCDLarge=on
    OptionUSBLarge=on
    'if the cd or pendrive has many mp3 (up 4GB) RR takes a long time to create playlist, then if the option is enable, ASRR not does the playlist in automatic mode and will user make one to the browser skin. So long as the user not creates the playlist the corresponding indicator will flash and you can not click on it for the switch multimedia device (default off)
    OptionUSBHardDrive=on 'This option allows you to manage a USB HDD as a PENDRIVE (default off)
    OptionLabelPlayList=on 'This option allows the user to view any valid label command using the label playlist (default off)
    OptionLoadPlayListOnTheFly=on 'This option allows you to create a playlist and to load it on the fly. The playlist will saved in directory playlist. If the playlist is a USB playlist, ASRR will make a directory in PENDRIVE (default off)
    OptionModifyPlayListOnTheFly=on 'This option allows you to edit a playlist on the fly if the contents of the PENDRIVE has been changed (default off)
    [ASRROptionDrive] 'sygic drive options
    OptionSkinNoChange=on 'If this option is enabled, ASRR do not changes skin user when Sygic Drive gives a vocal indication (default off)
    [ASRROptionMotionlock] 'motion lock options
    OptionNagScreen=on 'enable nag screen (default off)
    [ASRROptionScreenlock] 'screen lock options
    [ASRROptionScreensaver] 'screen saver options
    MenuSkin=on 'this option can not be changed
    AudioSkin=on 'enable IDLE on this screen (default off)
    RadioSkin=on 'enable IDLE on this screen (default off)
    [ASRRSetting] 'start settings
    [ASRRGeneralSetting]
    WAVolumeValue [0 - 255]=50 '(default: 50)
    Language [italian - english]=italian '(default: italian)
    [ASRRAudioSetting] 'multimedia settings
    UserTimerUnMute [min]=5 'time after which RR goes to unmute and play (default 5, minimum 1, if you insert 0 the command is disable)
    UserTimerSwitchLabel [s]=20 'time to switch the label playlist. If the option is enable, the plugin makes switch the playlist name, genre, data, time and any valid label command (default 20)
    UserLabel=Welcome to RoadRunner 'insert user text (default Welcome to RoadRunner)
    UserLabelCode1=TAGGENRE/ 'insert valid label command (default TAGGNRE/)
    UserLabelCode2=TIME/DATE 'the label will be displayed together (default TIME/DATE)
    UserLabelCode3=EnterCode/EnterCode or ,EnterUserLabel
    UserLabelCode4=EnterCode/EnterCode or ,EnterUserLabel
    UserLabelCode5=EnterCode/EnterCode or ,EnterUserLabel 'for example: MBM01/, RPM CPUFan and the result is 3750 RPM CPUFan ("label code" + "/" + "," + "user label")
    [ASRRDriveSetting] 'drivemon settings
    DriveExitDelay [s]=5 'time after which RR goes back in the previous skin (default 5, minimum 1, if you insert 0 the command is disable)
    UserSkinNoChange1=MENU.skin (for example, in this case RR doesn't change skin when sygic drive gives a vocal indication)
    UserSkinNoChange2=EnterSkin
    UserSkinNoChange3=EnterSkin
    UserSkinNoChange4=EnterSkin
    UserSkinNoChange5=EnterSkin
    [ASRRMotionlockSetting] 'motion lock settings
    COMMPort=2 'insert a free CommPort (default 2)
    Speed=30 'insert speed: if speed of the car is higher than that inserted, then the user skin (for example video player skin) is locked (default 30)
    ErrorSpeed [%]=0 'difference between the speed detected by the gps and the car (default 0)
    SpeedUnit [km/h - mph]=km/h 'speed unit (default km/h)
    CMD/TVSkin=TV/TV.skin '(default)
    CMD/VIDEOSkin=VIDEO/VIDEO_PLAYER.skin '(default)
    CMD/DVDSkin=LOAD;POWERDVD_PLAYER.skin||SENDKEY;{ENTER}/POWERDVD_PLAYER.skin '(default)
    CMD/USERSkin1=EnterCMD/EnterSKIN
    CMD/USERSkin2=EnterCMD/EnterSKIN
    CMD/USERSkin3=EnterCMD/EnterSKIN
    'enable skin for the lock of "motionlock"
    [ASRRScreensaverSetting] 'screen saver settings
    OpacityStart [0 - 255]=80 'opacity start value (default 80)
    OpacityEnd [0 - 255]=200 'opacity end value (default 200)
    'if you want the opacity, you must enter this:
    visuname=!Winamp Gen!AVS
    transparentvisu=true
    opacityvisu=100 (0-255 possible values)
    in the RR.ini file; if visuname=MilkDrop, then the opacity will not work!!!
    if opacity start value is 200 and opacity end value is 20, the screen saver will be more transparent than at the beginning!!!
    if opacity start value is 0 and opacity end value is 0, the screen saver will be set on the transparency of the RR.ini file (opacityvisu=100 for example)!!!
    OpacityFade [min]=5 'time after which the screen saver reaches the final opacity (default 5, if the value is 0 the screen saver will be set on the transparency of the RR.ini file)
    Idle [min]=5 'insert idle value (default 5, if idle value is 0 the screen saver is disable)
    [ASRRCache] 'this value not be changed!!!
    [ASRRAudioCache]
    CDSize=0
    USBSize=0
    CDPlay=off
    USBPlay=off
    CDDrive=F:\
    USBDrive=J:\
    AudioPlay=on
    PlaylistName=Avril Lavigne - Nobody's Home
    [ASRRMotionlockCache]
    Status=off
    [ASRRScreenlockCache]
    Pinlock=1234 'insert the pin (default 1234)
    Modify skin
    The buttons screenlock and motionlock are hidden and are located on the logo (sx,dx). To exit you must hold for a few seconds the buttons. If the indicator of motionlock "ML" doesn't flashes, you not has a valid GPS signal, then the command will locked!!!
    If you hold for a few seconds the button VISU, ASRR sends the command NEXTVISU, then if you click on visu ASRR sends the command NEXTVISU. If you hold for a few seconds the button VISU, ASRR sends the command PREVVISU. If you do not click on visu for a time of 5 seconds you exit the setup!!! Same for radio skin. I hope that I explained well. If you hold for a few seconds the button LIST, ASRR sends the command EJECT.
    If you do click on DVD indicator, ASRR sends the command EJECT.
    functions of the numeric pad when Screen Lock is enable:
    1- "ESC": exit
    2- "Canc": deletes a character
    3- "+": insert new pin
    4- ".": none
    5- "1", "2",...: insert pin
    1- menu.skin
    X,ASRR
    X,RRPDC (PDC-ROBBY-BMW)
    X,RRTMS (RTMS-ROBBY-BMW)
    I08,698,94,38,28,"SCREENLOCK"
    I09,738,94,38,28,"MOTIONLOCK"
    B15,3,532,154,63,"CAM",@TCAM@,"" (TrafficCAM-ENFORCER)
    B16,162,532,154,63,"ASRRTMS",""
    B20,330,237,55,92,"SCREENLOCK_ON",@SCREENLOCK_OFF@ ,""
    B21,417,237,55,92,"MOTIONLOCK_ON",@MOTIONLOCK_OFF@ ,""
    2- audio_player.skin
    I05,299,70,40,26,"MODE_CD"
    I06,341,70,46,26,"MODE_USB"
    B03,144,144,68,86,"VISU",@NEXTAVS@,""
    B08,213,232,68,86,"LIST",@EJECT@,""
    3- audio_menu_playlist.skin
    4- audio_browser.skin
    B01,6,272,68,57,"PATH_HDD",""
    B02,76,272,68,57,"PATH_CD",""
    B03,146,272,68,57,"PATH_USB",""
    5- radio_player.skin
    B07,144,232,68,86,"VISU",@NEXTAVS@,""
    6- video_player.skin
    I03,455,82,40,26,"MODE_CD_VIDEO"
    I04,497,82,46,26,"MODE_USB_VIDEO"
    B13,659,157,64,86,"LIST",@EJECT@,""
    7- video_browser.skin
    B01,6,360,68,57,"PATH_HDD_VIDEO",""
    B02,76,360,68,57,"PATH_CD",""
    B03,146,360,68,57,"PATH_USB",""
    8-powerdvd_player.skin
    I01,212,25,55,35,"MODE_DVD"
    You can click on the indicators CD-USB-DVD (no click on the indicators skin video)
    I hope you like it and sorry for my english!!! bye Niko73
    ASRR.zip
    Jun 2008
    Atlanta, GA
    Quote Originally Posted by niko73 View Post
    [ASRRLicense]
    You hoping to charge for this?
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Very nice and very clean
    Aug 2007
    Bologna, Italy
    Quote Originally Posted by spamminator View Post
    You can look at: http://www.carputer.it/showthread.php?t=7777
    Enforcer:
    "Thanks for the explanation. Looks like a nice plugin, maybe it needs to be publicised on MP3 car as well."
    bye
    niko73
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    this is certainly new in here!!! we have seen many things but...requesting money for a plugin that runs over a free software is certainly new! hope guino approves it
    Aug 2007
    Bologna, Italy
    Quote Originally Posted by Nomader View Post
    I don't want money...
    If you like it, you must give me the MAC pc number, so I can make your license!!!
    There is a license, because the plugin should be used only by the users of the Italian forum: www.carputer.it
    bye
    niko73
    Jun 2008
    Atlanta, GA
    bye
    niko73
    Ah, ok.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    bye
    niko73
    Ummm if this is limited to users of the "Italian Forum".... then I have to ask, why don't you just post it there? I mean posting a plugin on the MP3Car forums, in the plugins section, for a plugin that can not be used by the Mp3Car forum members just does not make sense to me.
    It is a nice plugin by the way.....
    My Fiero Build Thread
    Aug 2007
    Bologna, Italy
    Quote Originally Posted by JohnWPB View Post
    Ummm if this is limited to users of the "Italian Forum".... then I have to ask, why don't you just post it there? I mean posting a plugin on the MP3Car forums, in the plugins section, for a plugin that can not be used by the Mp3Car forum members just does not make sense to me. On top of that you are using MP3Car to host the file???
    This is bordering really close to spam actually.... I will have to confer with the elders on this one hehehe
    Nooooooooooooooo!
    Perhaps I have explained not good!!!
    I said that the license was used initially for the Italian forum!!!
    All users of MP3Car can have a free license!!!
    The plugin also works in demo version...you should compile the code again to remove the license, I do not see why.
    If you like it, you must give me the MAC pc number, so I can make your free license!!!
    niko73
  1. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 09:49 PM
  2. How do I setup TV / Camera Support ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 03:42 AM
  3. RoadRunner and HotKeys Support
    By Mr.Fabio in forum Road Runner
    Last Post: 02-08-2005, 02:10 AM
  4. Opensource or plugin support?
    By c4shm0ney in forum FrodoPlayer
    Last Post: 07-31-2004, 02:09 AM
