Page 2 of 50 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 499
Thread: Vehicle Maintenence Plugin
  1. #11
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    i was actually considering that last night. Should be easily done. I'd also like to come up with a cost per mile readout based on the cost label for each maintenance item but i'm not sure how to handle it. one thing i did have to do is scale the mile reading back to once ever 2 seconds because my timer that handles the calculation took more than a second the calculate and save to file. Gonna run this over the weekend and see if i come up with anymore bugs but for the last 2 days its been rock solid.
    also forgot to mention the status indicators are user definable. They are based on 3 .jpg files in the skin file. green.jpg, yellow.jpg, and red.jpg.
    Live mp3Car Facebook Chat
  2. #12
    Low Bitrate eigenVector's Avatar
    Apr 2009
    Quote Originally Posted by Sonicxtacy02 View Post
    What I like to do in this situation is queue the actual write to the file in a separate thread, so that the updates to the UI are pretty fast. Then on the background thread do bulk-writes to the file instead of one at a time. File access is much slower than in-memory access, but once you have a handle open for a file, you should be able to write lots of data to it quickly.
    Not sure what you're programming this in though.
    Great job, and good luck!
  3. #13
    Woodbridge, VA
    Blog Entries
    32
    I'm writing in vb.net.. and i'm a noob (still) dont know much about multi-threading. Spose now's a good time to read up lol.
  4. #14
    Apr 2009
    I'd help ya out, but I'm a C# developer, so the syntax issues will cause issues.
    But basically I create a separate class to handle writes to the file. If you're using .NET 2.0 or higher, use a generic Queue to Enqueue the item you want to write to the file system. Have a private method in your class that does a loop over the queue, dequeing each item and write it to the file system.
    Your class should have one System.Threading.Thread members in it, and have it point to the method with the write loop.
    Then just call the Start Abort method on your thread to start your looping method.
    Here's a really quick and dirty example written in C#, that has not been tested. But you should be able to get the idea.
    But yes, do some reading.
    Code:
    public class QueuedWriter:IDisposable
            StreamWriter writer; // writer use to actually write to the file
            Thread workerThread; // background thread used to perform the writes to the file
            Queue<string> itemsToWrite = new Queue<string>(); // queue of items that will be written to the file
            public QueuedWriter(string fileName)
                writer = new StreamWriter(fileName);
                workerThread = new Thread(mainLoop); // notice, we're specifying the mainLoop method in the constructor of the Thread
                workerThread.Priority = ThreadPriority.BelowNormal;
                workerThread.Start();
            public void WriteItem(string item)
                itemsToWrite.Enqueue(item);
            private void mainLoop()
                bool abort = false;
                while (!abort)
                    try
                        /// Write everything that has been queued
                        while (itemsToWrite.Count > 0)
                            writer.WriteLine(itemsToWrite.Dequeue());
                        //Nothing to write, sleep a while
                        Thread.Sleep(1000);
                        writer.Flush();
                    catch (ThreadAbortException)
                        abort = true;
            #region IDisposable Members
            public void Dispose()
                if (workerThread != null)
                    workerThread.Abort();
                workerThread = null;
                if (writer != null)
                    writer.Flush();
                    writer.Close();
                    writer.Dispose();
            #endregion
  5. #15
    Woodbridge, VA
    Blog Entries
    32
    i've got a c# to vb.net converter.. so that will help. Thanks!
  6. #16
    Nov 2004
    St Louis
    ... one thing i did have to do is scale the mile reading back to once ever 2 seconds because my timer that handles the calculation took more than a second the calculate and save to file.
    Maybe scale it back to 5 seconds for those of us with slow CPUs.
  7. #17
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Looking Good Sonic!
    This is looking good Sonic! One thing I would consider is to input the odometer reading when the plugin is installed and setup, and have that updated on the screen as well. This way you have a real world comparison to see how accurate it is keeping track of the millage. Also making the value clickable, and correcting / syncing it with the actual odometer would be a major plus.
    For a quick trip to the store, many of us do not have the computer come on, but would like to keep the "system odometer" in sync with those lost tracked miles ect. Also the "floating" of the lat and lon can add up pretty fast. Back when I was trying to get Festy's gas mileage thing to work, I noticed this. With the USB GPS puck here on the desk, I left it running for a day when I left in the middle of working on it and noticed that I had traveled a few miles hahah.
    As far as frequency of updates, personally I think once ever minute, 5 minutes or so is more than enough. Oil changes are the most frequent thing to change for example, & I doubt having to know within 2 seconds that's its time for an oil change is really going to matter that much
    This would decrease the overall CPU usage, as well as not constantly thrashing / writing to the hard drive every 2 seconds.
    As for the cost per mile for items, that should be fairly simple to do. In your example its $17.50 for an oil change that is done every 3,000 miles:
    $17.50 divided by 3000 = .006 cents per mile.
    I also completely agree, and would love to see a fuel log wrapped into this! Fill er' up, enter the number of gallons, price per gallon and the odometer reading. At the next fill up do the same, and you can then have it calculate many miles per gallon you are getting.
    My Fiero Build Thread
  8. #18
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    subcribe::
  9. #19
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by GizmoQ View Post
    I'll have it user settable... IF the threading idea falls through for whatever reason. If i can have the file IO done separate from the actual distance calculation it should work out great. Only problem would be if RR is closed between writes. RR really needs a way to let plugins know its terminating.
    Quote Originally Posted by JohnWPB View Post
    Can do
    I've got a kick out for floating coordinates that monitors the heading value. This should work really well... unless you guys are out doing high speed donuts lol.
    when i say the timer runs too fast at once per second only real issue is getting the lat and lon from RR before the CalculateDistance function is run. If RR hasnt reported back to the plugin before the function runs the result of the function is Nan and it crashes the system. I can probably easily write prevention for this.. but for now once every 2 seconds has been absolutely no issue on my 1.2ghz celeron i'm developing on.
    I will definitely add it in some capacity as it is pretty easy to do. i was thinking more along the lines of having to calculate each time the oil change is done.
    Will also incorporate this.
    One more thing i incorporated before leavin work on friday is a slider that gives you yet another visual indication of how close you are to exceeding your maintenance limit.
  10. #20
    Woodbridge, VA
    Blog Entries
    32
    I've been plugging away at this for the last few days and i have more progress. I've completed the setup and adding maintenance screens... and also optimized the calculatedistance function a little bit so that a Nan return isnt possible. I've also incorporated a concept similar to what eigenVector suggested to keep I/O overhead down.
    Next step is to work on the fueling information. Then adding a cost calculator.
  1. Replies: 13
    Last Post: 05-28-2009, 04:18 PM
  2. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
