*BUMP* any that has encountered the same thing? ie useing todays date everything is ok but if you use a date in the past then it dont work
using todays date for last time maintence is done solved the problem in my case
the only problem in that is that the plugin cant figure out when the maintence is due next time only if you pass the km interval first
still i see some $ for prices... could they be changed to a string in the ini ? in that way you can quickly set it to £ or whatever you want
Getting some weirdness here...
Is there any reason why my Fuel Log.ini looks like this:
All my fuel log data is gone...Code:9/23/2009 7:17:47 AM Jennie's Playlist Good Enough Drones Hate Me Boiler It'll Be Ok Defy You Never There Let It Die Gone Forever Just Like You I Hate Every![]()
Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
is that a music playlist? It appears some other plugin has intercepted the fuel lost custom lists data with its own.
Live mp3Car Facebook Chat
It looks like the tagcache.ini entries of my current playlist...at least, part of it.
Code:9/23/2009 7:17:47 AM Jennie's Playlist Good Enough Drones Hate Me Boiler It'll Be Ok Defy You Never There Let It Die Gone Forever Just Like You I Hate Everything About You Fine Again Ex's and Oh's Pushing Me Away I Don't Care Comfortable Liar Last Resort Not Listening Voices You Give Love A Bad Name Stay in Shadow Forfeit Blow Animal I Have Become Worth Dying For Love Song Revenge Love Hurts Cry Me A River (Remix) Faint One Step Closer Lying From You Hit The Floor Easier To Run Figure.09 Shut Up Scared Holier Than Thou Snakes I Don't Love You Pain Every Word Is A Knife In My Ear I Don't Think I Love You
Sonic, just ran into a problem that took some tracking down to narrow it down to the RRVM plugin. Each plugion needs to be moved out of the plugins folder one at a time, start RR, try a plugin with a slider, rinse and repeat
The RRVM plugin is preventing sliders in any other extension plugin from working
You probably just used the old Extension example source code. Quite a few changes were made to help prevent plugins from interfering with each other.
In your plugin source, in the sliders section, you need to make sure you have this line:
'This tells RR that the Slider was not processed in this plugin
ReturnSlider = -1
You may have something that looks like this if it is older code:
ReturnSlider = 1000! * Val(Format(Time, "SS"))
ElCamino had this in his YouTube! Plugin, (Mentioned HERE in post# 85) and it prevented sliders from working for any other plugin. He changed that line in the source, and all was well.
My Fiero Build Thread
Is it possible to add a language option in your RRVM plugin ?
Thanks , It run very well for me
i have no idea how one list got mixed in with another.. i'll check the name of the array that holds the fuel log perhaps it matches something in RR or another plugin.
i KNEW it needed to be fixed i just plain forgot about it. Its fixed now though and available at the download link
While i've got the source open (and have time) i'll take a look at doing that. The labels will still be named the same, but the resulting values will be based in $ISUNITS$. I will need testers for this stuff because my 90 day update window is up and dont feel like worry about finding a unbroken substitute at the moment![]()
3 bumps to ask the same question? Isnt it obvious noone else has reported the problem? Care to provide a debug.txt of it happening? What skin and RR version? What method do you use to enter your date data? What language settings do you use. You havent given a real great description of whats happening and what you're doing when it happens
