Originally Posted by
Blue ZX3
Got some Q's..
#1 At first run, it asks you how often to check for the milage, where is it saved, as i don't see it saved anywhere.
#2 When saving/updating the current Odometer in the file, you should also be saving the trip (resest when rr is restarted).
#3 Same goes for waypoints, if the starting point is set of course...
#4 Is there a way to also enter/adj the trip the way the odometer can?
As far as the throwing out bad gps data... i think that this should be handled just like the old milage PI did. Meaning that you make a min dist traveled (by setting), that when the dist is calc'd if smaller then most likely is just GPS wonder while sitting still.
I finally adding to my dfx skin in the car to start playing with this so I will probably have more Q's/req's and hopefully no issues...
Looking great from what i've played with so far..
