Page 36 of 57 FirstFirst ... 262728293031323334353637383940414243444546 ... LastLast
Results 351 to 360 of 561
Like Tree1Likes
Thread: Vehicle Maintenence Plugin
  1. #351
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    i get it at almost the same interval.. as soon i reg the dll i get it... if an item is due should there be a pop up? i dont get one
  2. #352
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i still dont know what you're talking about. The ding should only occur if you have maintenance items in the alert phase. It should only happen ONCE daily.. very soon after rr has been started. There is no pop up when maintenance is due.. there is:
    -the audible DING
    -the email is sent
    -ONCHECKMAINTENANCE event is done... you can use this even in exectbl.ini to create a popup or do whatever you want inside of RR when the maintenance item is deteceted as due
    Live mp3Car Facebook Chat
  3. #353
    Oct 2008
    Odense, Denmark
    i just get a ding every few minutes... and together with carputer i tracked it to coming from RRVM
    and i tried to unreg RRVM and the ding stopped... but i will try to replace the soundfile with another to make an extra check
  4. #354
    Oct 2008
    Odense, Denmark
    did an search for rrvm.wav on the entire drive (only have one) no rrvm.wav anywhere
  5. #355
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by boelle View Post
    Its gonna be very hard to find actually... as the sound is like a cheapie digital watch, and its usually hard to tell where the sound is coming from
    My Fiero Build Thread
  6. #356
    Woodbridge, VA
    Blog Entries
    55
    ok.. number 1.. use the LATEST version... i cant troubleshoot if you're using something old. Secondly, you're not telling me if you actually have a maintenance item due. If you dont, there's nothing programatically that can make the .wav file play. If you DO have a maintenance item due... do the maintenance, and reset the maintenance item.
    maybe RRVM.wav isnt the filename.. but there is a .wav file.. somewhere in the sample skin folder that you can replace. you could probably delete it but i dont remember for sure if i'm doing a file check.
  7. #357
    Oct 2008
    Odense, Denmark
    will check out first thing in the morning and report back....
  8. #358
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I too can say that the reminder sound(rrvm.wav) plays ~once every 2mins! Until I just got my oil changed and reset the that item, I heard it/put up with listening to it to/from work...
    It clearly does NOT just play once per day....FYI
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  9. #359
    Woodbridge, VA
    Blog Entries
    55
    I stand corrected.. the ding will occur on the specified timer interval until RRVM_DISMISS is run. Consequently, you can put "RRVM_ONCHECKMAINTENANCE","RRVM_DISMISS" in exectbl.ini and this will stop the ding after 1 go round.
  10. #360
    Jul 2006
    Hey Sonic,
    I haven't been able to send a report in quite some time. I've tried it on 3 different computers, and 3 separate internet connections. I get the attached popup when the report tries to send. Could we possibly set it up with our own SMTP information to fix the problem?
  1. Replies: 13
    Last Post: 05-28-2009, 04:18 PM
  2. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
