Page 43 of 57 FirstFirst ... 333435363738394041424344454647484950515253 ... LastLast
Results 421 to 430 of 561
Like Tree1Likes
Thread: Vehicle Maintenence Plugin
  1. #421
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    The first problem must be a setting you have wrong. Check the config file and make sure it days English and not English.ini
    the fuel log problems I'll have to fix when I get the time. I'm going to convert the fuel log to XML so that it's easier for me to work with. It wil also help compile the vehicle report. At the time of me making this plugin I was great will text I/O but I'm pretty versed in it now.
    Using the 10/30/2009 version.
    First, upon RR startup, I get this error msg. I have unreg/re-reg the plugin and still ocurrs. Notice the path: "..\Lang..\English.ini\..." Partically the bold part.
    Next, I know that the fuel screen is only supposed to list the last 20 entries, which it actually lists the last 21 entries. But, upon entering the next fill up, when you get to the last entery point ( # of Gal ), it will not continue no matter how many times you rap on the 'Enter' button, the only way out it to cancel it.
    Along with this, I have noticed that as soon as you have more than 22 lines in the fuel log.ini file, that the fuel log list never get the entries added. It stays empty.
    Also, after you first go into the fuel screen, you must load the file, but never release it and changes can be made until user closes RR. Minor, but really should only have the file open for the reading only.
    Live mp3Car Facebook Chat
  2. #422
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yep, that did fix my fist issue!
    I know that this is going to be the wrong question to ask, but an ETA on a fixed/updated PI?? I only ask, because of the pending DFX release.
    Thanks.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #423
    Woodbridge, VA
    Blog Entries
    55
    Thanks.
    I will see if i can get it out in the next day or two, depends on the post-holiday workload and how deep into the code i have to roam.
  4. #424
    Woodbridge, VA
    Blog Entries
    55
    Ok Blue i sent you and John an invite to the latest beta completed today. The invite email (from sonicxtacy02 at hotmail) will contain instructions, but basically you only need copy RRVehicleMaintenance.dll and fuel_log.xml to the RRVM plugin folder. What would be neat is if someone could create an autoit script to convert the old .ini based fuel log to the new format.
    I've also updated the "date" code so that people with non-USA date formats should be able to better use RRVM.
    This change should help not only make the fuel log more reliable but also fix the missing data from the email report. Eventually i'd like to convert the scheduled maintenance and history to .xml too.
    Lemme know how it goes
  5. #425
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Anyone else getting a "No Language File Present" (or something like that) error on all the RRVM labels when resuming from hibernation?
    I know that the file is there because closing RR and restarting, everything with RRVM works fine.
    Resume then hibernate, and all the labels are out to lunch.
    The skin files are not preloaded or cached on resume.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  6. #426
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Could it be realated to being a HORM setup? I have no issue besides the mentioned using standby/resume.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #427
    Aug 2006
    Sun Diego
    Maybe?
    I also wondered if it's related to the fact that I have the max 10 screens loaded in rr.ini and I have 6 of them listed to keep loaded?
    I can't quite remember when this started. Just started to notice it in the last few weeks b/w fill ups and I've been on the same hib image since March.
  8. #428
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    Is there a way to expand the SC for the Fuel Log?
    For my skin, I'm liking the idea of having the list spread more across the screen, as I'll be putting buttons and such below (being a vert screen I've got a bit more realestate)
    It seems as though the information is being formatted at set spacing, is there a way to 'easily' modify the spacing?
    In the fuel log.ini it's the @ symbol that's acting as the space.
    Any update on an update?
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  9. #429
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by sargeants View Post
    no there's no current way to stretch the SC.
    And as for an update? Beats me i sent it to testers weeks ago and as far as i know it hasnt been downloaded.
  10. #430
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Sonicxtacy02 View Post
    Got to love that when that happens.
  1. Replies: 13
    Last Post: 05-28-2009, 04:18 PM
  2. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
