Page 46 of 53 FirstFirst ... 363738394041424344454647484950515253 LastLast
Results 451 to 460 of 530
Thread: Vehicle Maintenence Plugin
  1. #451
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Don't ya just love "standards"... LOL
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #452
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    yep, specially those who makes sense.
    Blessed are the "cracked" for it is they who let in the light.
  3. #453
    Oct 2008
    Odense, Denmark
    another Q....
    I just got a canbus adapter so that i can feed signals like park brake etc to the pc and make use of the factory stalk.
    It also have a speed pulse output, would it be possible to use that to count up the odometer in RRVM ?
    As for gps my antenna is the one garmin supplies with their mobile pc software, sadly it does not show up as a serial device so it cant be shared, not that i mind since the gps has a bad habbit of adding miles even thou not driving.
  4. #454
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by boelle View Post
    another Q....
    i dont currently have a canbus device so i'd have no way to test that feature. Anyone know of a canbus simulator that wont break the bank?
    Live mp3Car Facebook Chat
  5. #455
    Oct 2008
    Odense, Denmark
    you might not need one, my adapter outputs a square wave signal at 1 hz per km/h... will check up to make 100% sure.
    My thought was to use that signal and in some simple way feed it to a ser. port or a usb to serial.. then make the plugin count the pulses that way... just a thought
  6. #456
    Oct 2008
    Odense, Denmark
    yep just read the 1 Hz per km/h figure on a spec sheet for another adapter so it seems to be a general signal.
    on my adapter it's used interface an aftermarket radio to the car... so i'm pretty sure the signal is more or less a standard.
  7. #457
    Oct 2008
    Odense, Denmark
    do RRVM calculate distance by messureing speed and time?
    if so a small plugin that tells RR the speed would do... or am i total off track?
  8. #458
    Woodbridge, VA
    Blog Entries
    53
    It calculates by taking the difference between current lat/lon and last lat/lon. I would have to release another version which takes speed and time into the equation (basically the way CFVM uses OBD data)
  9. #459
    Oct 2008
    Odense, Denmark
    i have been playing arround with the idea of a small PIc that counts pulses for a sec and passes that number on as serial data...
    hmm... would it be possible to read this on the serial port:
    60,60,60,60....
    ie that the comma tells RRVM that the speed is the number from one comma to the next?
    just small thoughts
  10. #460
    Woodbridge, VA
    Blog Entries
    53
    i can read whatever data you pass via serial
  1. Replies: 13
    Last Post: 05-28-2009, 03:18 PM
  2. Replies: 63
    Last Post: 03-10-2009, 07:49 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  5. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
