Page 47 of 53 FirstFirst ... 3738394041424344454647484950515253 LastLast
Results 461 to 470 of 528
Thread: Vehicle Maintenence Plugin
  1. #461
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    ok,
    i just found some good instructions to let me use a picaxe chip to count pulses for 1 sec and pass the number of pulses to the serial port and jump to a new line ie
    60
    66
    50
    70
    65
    one new line every sec...
    or it could be one line every half sec...
    now for the maybe bit more tricky part... this signal that i count is 1 hz per km/h.... now is the format the same in the us... ie 1 hz per mile/h
    it seems to be standard some way, but to make sure we need a small test app and compare the readings to the cars own speedometer to make sure
    thinking on at my end
    Blessed are the "cracked" for it is they who let in the light.
  2. #462
    Oct 2008
    Odense, Denmark
    for those who know about the picaxe here is the code i'm going to test out next week (need parts to build test curcuit):
    Code:
    main:
    count 1, 1000, w1 ‘ count pulses in 1 second
    debug w1            ‘ display value
    goto main            ‘ else loop back to start
    Set Serial port to 4800, N, 1 and every sec there should be a new line in programs like Hyber Terminal
    Rough schematic:
    J1 is 12V Square Wave input - J2 is output to a Serial programming cable, pin 1 & 3 are the the ones need for the output
  3. #463
    Oct 2008
    Odense, Denmark
    i just revised the schematic to have volt output also:
    Code for the picaxe:
    Code:
    main:
    count 1, 1000, w0  ;count pulses in 1 second
    Readadc 2 , B2	   ;Read the battery voltage and store it in B2
    sertxd ("The Speed Is: ",#w0,cr,"And The Voltage : ",#B2)
    goto main          ;else loop back to start
    output will be
    Code:
    The Speed Is: 0
    And The Voltage : 0
    The voltage needs to be converted like this: 12 / 255 * Voltage read
    Did try it in the picaxe but it seems to make an overflow
  4. #464
    Newbie diverdeep's Avatar
    Sep 2010
    Good day, I wish to try your plugin, but I cannot download from link. Where I can download it? MAny thanks
    Quote Originally Posted by Sonicxtacy02 View Post
    I've developed a standalone maintenance tracker application and im considering porting it over to an RR plugin (long overdue IMHO). The standalone works by calculating the distance between GPS coordinates which calculates the total distance traveled, then weighs that figure against his preset maintenance intervals. Im surprised to say the distance calculation works very well! I've tested it over the last few days side by side with iGuidance and the distances are spot on. Finishing the application should be a matter of using a timer to calculate the difference between the interval value and distance value.. but while i'm still tinkering with distance calculation i'm curious to see if anyone can think of any other potential uses for it.
    Beta 2 Released 10/30/09
    http://cid-742b075baeb78d0d.skydrive...ublic/RRVM.rar
  5. #465
    Organic Me
    Heather's Avatar
    Sep 2007
    Fells Point, Baltimore, MD
    Blog Entries
    48
    Quote Originally Posted by diverdeep View Post
    LINK
    Use firefox, not ie to download.
  6. #466
    Sep 2010
    Thanks, but this is for CentraFuse, not for Ride Runner? I'm searching for RIdeRunner
    Quote Originally Posted by Heather View Post
    LINK
  7. #467
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    43
    link is post 1 is fixed. Here is where you download the software now
    https://autoappmart.com/products/RRV...aintenance_137
    Live mp3Car Facebook Chat
  8. #468
    Woodbridge, VA
    Blog Entries
    43
    Does anyone who downloaded RRVM early on have the PSD's for the carwings skin? I know i used to include them in the releases. I have some upgrades to do but i lost the skin files in computer transition
  9. #469
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    sorry fro bumping the thread , but what was rrexteneded used for in your PI , as i have issues useing rrexteneded , just want to know how important that the pi NEEDS IT
    & sorry i don't have the psd's anymore for this PI
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  10. #470
    Woodbridge, VA
    Blog Entries
    43
    I just scanned the source and i dont see any where i'm using RREXTENDED stuff. It was probably done with the rounding or something.
  1. Replies: 13
    Last Post: 05-28-2009, 03:18 PM
  2. Replies: 63
    Last Post: 03-10-2009, 07:49 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  5. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
