Page 50 of 53 FirstFirst ... 4041424344454647484950515253 LastLast
Results 491 to 500 of 529
Thread: Vehicle Maintenence Plugin
  1. #491
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Maybe I need to find its breaking point... But then, that would require for me to put my carpc back in the car where it belongs and install this newer version.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #492
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    49
    Bit of an update for my favorite plugin. User Barnyard has been working pretty hard with me to nail down some of the Pro Mode stuff. Database backup and restore are now working great. There has been a lot of code optimization and error prevention added. GPS Tracker has been working great. The footprint of the debug file will reduce dramatically, as will errors resulting in the loss of local data. I've tidied up the carwings skin, making it "lite" compliant and changing the "wing" commands to reflect some of the pro mode features. OBD support will soon happen!
    ---------- Post added at 04:16 PM ---------- Previous post was at 02:42 PM ----------
    obd screenie
    Live mp3Car Facebook Chat
  3. #493
    Woodbridge, VA
    Blog Entries
    49
    well after 3 straight weeks of coding and testing i now have RRVM talking to OBD. I could use a few testers to see what obd devices will be supported. If you have a OBD reader and are interested in testing please let me know. It'll take a day or two to flesh out the skin and configs but at least i'm reading and writing pids!
  4. #494
    Oct 2006
    If you still need testers I have the Elm Scan 5 USB and would be willing
  5. #495
    Aug 2010
    Hi there, I am just getting this plugin to work with the latest RR and Reborn Skins. I have made some graphics and modified the skin files to better suit the Reborn style but have run into an issue and can't for the life of me figure out how to fix it.
    When I add an entry in the fuel section the "month" section of the date gets an extra 0 added to it so today's date ends up being 21/007/2011.
    Is this something anyone else has encountered? I searched the Thread but didn't seem to find any results so any help would be appreciated.
    Cheers
    EDIT: Just to add that my date format is DD/MM/YYYY but I have tried changing to "short date" and others with no luck.
    Also the date displayed in the "last refuel date" is correctly displayed.
    EDIT2: I am also having trouble withe slider. If the task is past due I see the final image in the slider, If the task has just been entered with full time left to go I see the 1st image but if the task is anywhere in the middle I see nothing at all.
    How many images are supposed to be in the slider or does it not matter? I have 20.
  6. #496
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    Not that this is maintenance related, but if you want one more OBD value (for those of us with TurboChargers or SuperChargers), here's a formula for calculating engine-boost that I use, and seems to be accurate.
    BoostKPA = MAP_KPA - 100
    if BoostKPA < 0 then BoostKPA = 0
    (this matches what my boost gauge reads, after converting to PSI of course.)
  7. #497
    May 2007
    This is a cool plugin but I have run in to a couple of issues. It looks like a debug routine is running logging data constantly.
    I am not sure if it is related to the debug or not but it also increases my CPU usage about 30% or so. The next issue I have is every time I start RR I get an alert about a maint. issue but I have not added anything yet.
    What do I need to do to get the OBD working?
  8. #498
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I have a bug to report!
    Fresh DFX5 install, July RR, RRVM 2.0.2 just DL from appstore...
    On the first run of the plugin it asks for all the info, and just after that process is done, i get a notification that "" maintaince item needs checked popup fired from its event. But I haven't even added an item yet... attached is my settings xml if it helps any?
    Attached Files Attached Files
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #499
    lep
    lep is offline
    Jul 2011
    1] how to delete a list item?
    2] how to report the item to the "oil change" has already been done!
    thanks
  10. #500
    Newbie whteglve's Avatar
    May 2006
    Clemmons, NC
    FIleNotFound?
    I'm testing this plugin on my laptop before installing in the car. The problem is that when I first RRVM for the first time it asks for the mileage and interval. Then it immediately says that the item is overdue. It never asks what the interval was for. Also when I try to reset the item it asks for cost and gives me a window that says in short file not found. (See attached) What am I doing wrong?
  1. Replies: 13
    Last Post: 05-28-2009, 03:18 PM
  2. Replies: 63
    Last Post: 03-10-2009, 07:49 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  5. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
