I will update the plugin tomorrow to avoid this problem.
Ya, if you look two post up at my previous post, you see that I mentioned the same issue back in Aug and sonic has yet to say/do someting about it yet... Hmmm....
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Live mp3Car Facebook Chat
I know that you guys think that I'm an idiot by now. Blue - I read your post but it sounded like a similar bug but then again not.
Hi. Thanks for a very good and useful plugin.
There is a small bug in it - if the date format separates with dots "." the fuel screen didn`t display the records from fuel.xml file.
And can anyoune help, how to configure Unitvar, fuelvar, ReportTitle1 and others? I tried type them in the xml file, in the skin files.... mb i do smth wrong?
How can i configure plugin to use metric values?
Thanks for help)
I will be (finally) releasing the rebuild of this application today. Among other things, this rebuild has:
-New language (C#)
-New more accurate distance calculation method
-UI enhancements for data entry
-Fuel log now accepts date value
-Greater internationalization settings
-Updated language file (English only, please contribute by updating other languages based on english.xml)
-Vehicle information report fixed
-Asynchronous online/offline support, no longer should RRVM ever slow down RR.
-Maintenance Tracker, Fuel Log, Repair history can all be backed up/restored from my server.
-Easy to use settings screen for MOST RRVM Settings.
-Free GPS Tracker*
-Preliminary OBD-II (Elm 327 compatible) support**
*GPS Tracking is handled either by my tracker server or your own php based solution.
**OBD-II support is definitely BETA, any OBD pros want to contribute by all means i'll show my connection codes.
This update has literally been months in the making and i hope it offers a more pleasant RRVM experience. Will update this post with download link later today.
EDIT: https://autoappmart.com/products/RRV...aintenance_137
Realy thanks Sonicxtacy02 for this new version that wonderful.
Just some things that you can may be to add is the possibility to change the money (i should like € for the Europe, and litre for the fuel capacity).
French.ini file:
[FirstRun]
FirstRun1Title=Configuration de la maintenance du véhicule
FirstRun1Text=Prenez le temps, svp, de configurer le plugin de Maintenance. Appuyez sur Suivant pour entrer votre kilométrage actuel.
FirstRun1Opt1=Suivant
FirstRun1Opt2=Annuler
FirstRun2Title=Entrez votre kilométrage actuel
FirstRun3Title=Entrez l'interval entre chaque calcul (en ms)
FirstRun4Title=Entrez la capacité de votre réservoir
FirstRun5Title=Merci
FirstRun5Text=Les configurations sont maintenant terminées. Voulez-vous entrez les données de maintenance maintenant?
FirstRun5Opt1=Oui
FirstRun5Opt2=Non
FirstRun6Title=Entrez votre email pour le rapport de votre véhicule
FirstRun7Title=Année de fabrication du véhicule
FirstRun8Title=Marque du véhicule
FirstRun9Title=Model du véhicule
JanuaryText=Janvier
FebruaryText=Fevrier
MarchText=Mars
AprilText=Avril
MayText=Mai
JuneText=Juin
JulyText=Juillet
AugustText=Août
SeptemberText=Septembre
OctoberText=Octobre
NovemberText=Novembre
DecemberText=Décembre
[Maintenance]
MaintenanceTitle1=Entrez le nom du profile de la maintenance
MaintenanceTitle2=Année où elle a été dernièrement realisée
MaintenanceTitle3=Mois où cette maintenance a été realisée
MaintenanceTitle4=Jour où cette maintenance a été realisée
MaintenanceTitle5=Entrez le kilométrage où cette maintenance a été realisée
MaintenanceTitle6=Entrez le kilométrage entre chaque maintenance en $UNITVAR$
MaintenanceTitle7=Entrez le nombre de jours entre chaque révision
MaintenanceTitle8=Entrez le coût pour chaque révision (Dollars and Cents)
MaintenanceTitle9=Entrez toute notes pour ce profile. Pressez Entrée Pour Passer
[Fuel]
FuelTitle1=Ajuster kilométrage lu, si besoin
FuelTitle2=Entrez le coût du carburant en Dollars and Cents
FuelTitle3=Carburant ajouté en $FUELVAR$
FuelTitle4=Année de cet ajout
FuelTitle5=Mois de cet ajout
FuelTitle6=Jour de cet ajout
FuelTitle7=Kilométrage lu lors de cet ajout
[Repair]
RepairTitle1=Entrez le nome de cette réparation
RepairTitle2=Année de cette réparation
RepairTitle3=Mois de cette réparation
RepairTitle4=Jour de cette réparation
RepairTitle5=Entrez le kilométrage lu lors de cette réparation
RepairTitle6=Entrez le coût de cette réparation (Dollars and Cents)
[Reset]
Reset1Title=Reset Maintenance Item
Reset1Text=Cliquez pour mettre à zéro l'interval des maintenances pour $MAINTENANCESELECTED$
Reset1Opt1=Mise à jour
Reset1Opt2=Annuler
Reset2Title=Svp, entrez le coût de ce profile (Dollars and Cents)
[History]
HistoryFilter1=Tous les profiles
HistoryFilter2=Carburant Log
HistoryFilter3=Révision
HistoryFilter4=Réparations
[Maintenance Item]
Reset1Text=Click to reset the maintenance intervals for $MAINTENANCESELECTED$
Reset1Opt2=Annuler
Reset2Title=Svp, entrez le coût de ce profile (dollars and cents)
[History]
HistoryFilter1=Tout
HistoryFilter3=Maintenance
It is possible to edit it in skin files.
Thanks for a new release. It is good way to solve data problem and add more additions.
There is small problem with adding fuel entry. After entering: 1- Year, 2- Month, 3- Day, 4-Adjust Odometer, 5- Current Odometer, 6-Fuel costs, 7- Fuel added in litres... it should be end of procedure, but instead of it a new rrvm_numpad appear without any title and it is possible entry any in it, ok button didn`t take result, just cancel, but it cancel all entered information.
Maintenance add entry works great, without problem.
Also didn`t you think add a such thing as "Full tank" For example if i fill a full tank, it is possible more accurate calculate amount of fuel gone and killometers drived from last full tank refill. a
Thanks again for a great plugin.
thank you i'll add it to the compiler
It's funny, fuel entry is what i spent 2 whole days on last week before releasing this and something still slips up regardless if using $ISUNITS$ or not. I'll work through it today and drop a hot fix. BTW, i dont ask what a full tank is because I already asked for your max fuel volume. With that information i already know based on calculated MPG and added volume whether its a full filling or not. Your MPG is calculated using the amount of fuel spent between fillings, not just the overall distance driven.
To calculate a mpg you need to know exactly (or approximately) amount of fuel left in the tank. For example: I can fill it up full or just 5 liters (not enough money... bad gasoline... ) if there is no access to fuel flow sensor or gasoline tank gauge you can`t get amount of gasoline left in it. Just when i fill full tank, it can be a good additional calculation point. Or it will be always approximately calculated values, because after each filling it is still unknown did the tank filled half or 3\4 or a full. It is as i see it, sorry if i am wrong.
Ssory if i am wrong, just want that your plugin be the best one)
Awaiting for hotfix.
Best.
