Page 52 of 57 FirstFirst ... 242434445464748495051525354555657 LastLast
Results 511 to 520 of 561
Like Tree1Likes
Thread: Vehicle Maintenence Plugin
  1. #511
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Yea i kinda reconsidered my calculation protocol for partial fillups tonight while fixing the adding fuel process. So from now on when adding fuel, if the added fuel amount is less than 80% of your stated fuel capacity, you will receive one more "menu" screen asking if the refuel is a partial fill. If the IS partial, it will not contribute to the calculation of the overall MPG data. I've looked around for similar apps and that appears to be the manner in which its handled, or should i say unhandled lol.
    Version 3.1.5 will be out in the morning, gonna take me just a bit to revise the XML and fuel screens.
    Live mp3Car Facebook Chat
  2. #512
    Woodbridge, VA
    Blog Entries
    55
    Hey pierrotm777, mind translating these two lines in french for the .ini?
    FuelTitle8=Refuel Type
    FuelTitle9=Is this a partial refill?
  3. #513
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by Sonicxtacy02 View Post
    FuelTitle8=Remplissage type
    FuelTitle9=Est un remplissage partiel?
  4. #514
    Woodbridge, VA
    Blog Entries
    55
    Updated to 3.1.5. on the carwings skin you'll notice on the fuel screen icons that indicate a full fuel or a partial fuel. Again, partial fuelings are calculated but there results do not impact the overall mpg rating.
  5. #515
    Newbie whteglve's Avatar
    May 2006
    Clemmons, NC
    I'm having a problem with starting RRVM. I'm running RR (2/5/2012) and the latest copy of RRVM. In the DFX skin RRVM is there and kind of works but says it's missing the RRVM_listdialog.skin. So I switch to Carwings to check things out. I can't find it in Carwings but RR says that it's loaded and enabled. Should I have done something special other than the regular install? Do I need to edit the skin?
  6. #516
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by whteglve View Post
    RRVM_ListDialog.skin is included in the installer and should have been copied to the Carwings_Dynamic_Lite folder along with the rest of the RRVM files. DFX has not been updated for the additions made just last week. Verify that RRVM_ListDialog.Skin does not exist in the carwings folder, and if it doesnt i'll just attach it here for you.
  7. #517
    May 2006
    Clemmons, NC
    Sorry if I sound stupid I'm not a programmer. Thanks Sonicxtacy I'll check when I get home.
  8. #518
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    a couple of notes on the new release
    I could not enter my vehicle's information correctly, wasn't able to select my model 97 S10 Blazer, wasn't available in the lists.
    Vehicle year list only went down to 1992, although vehicle specific list covers earlier models
    (Not sure how important those are, however I would like to be able to set them correctly, I guess I could always edit the xml file if its not that important)
    Didn't ask for a GPS or OBDII port (back to the xml file)
    Didn't ask for engine capacity, MAF mode, oh and there seems to be a timeout on entering info, this is too short
    C.E.L. button on OBD-II skin throws an error, rrvm_mil.skin not found
    looking at the xml file...
    DTELowThreshold
    OBDVE
    GPSCrawlAvoid
    StandaloneGPS
    ???? it would be nice if descriptions for these values were included in the readme file
    Maybe it could use a skin for setup/modification of all these settings.
    Can't wait to try out the tracker feature.
    Sure is weird having carwings skins within DFX
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  9. #519
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by DaveDog View Post
    DTELowThreshold
    OBDVE
    GPSCrawlAvoid
    StandaloneGPS
    Why couldnt you enter odometer? It's just a numOSK screen with a label. Press the button and nothing happens?
    Your car is listed, the problem is i parsed a source for chevy instead of manually inputting each model and the source came with the model year as its shown. I will correct the file.
    Check engine button does not current work and is a known bug
    As for the rest of your questions, use Carwings, go to plugin manager, click rrvehiclemaintenance, then click settings. MOST settings outside of the initial stuff can be set there.
  10. #520
    Mar 2004
    Greenacres, WA
    I didn't mention not being able to enter odometer, not sure where you got that idea, it works fine.
    Never thought of the settings in plugin manager, like you said, most of the settings are there, still no settings for engine capacity or MAF, do these not matter?
    I understand avoid GPS creep, but not StandaloneGPS/Use External GPS, (I assume these are the same, just labeled differently) does that mean not to use the GPS configured for RR?
    Still do not know what these others mean
    DTELowThreshold
    OBDVE
    again, it would be nice to include this info in the readme file, especially using plugin manager to finish setting things up.
    I hope you find my feedback useful
    Keep up the good work!
  1. Replies: 13
    Last Post: 05-28-2009, 04:18 PM
  2. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
