Page 53 of 53 FirstFirst ... 34344454647484950515253
Results 521 to 528 of 528
Thread: Vehicle Maintenence Plugin
  1. #521
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    43
    Quote Originally Posted by DaveDog View Post
    I didn't mention not being able to enter odometer, not sure where you got that idea, it works fine.
    Never thought of the settings in plugin manager, like you said, most of the settings are there, still no settings for engine capacity or MAF, do these not matter?
    I understand avoid GPS creep, but not StandaloneGPS/Use External GPS, (I assume these are the same, just labeled differently) does that mean not to use the GPS configured for RR?
    Still do not know what these others mean
    DTELowThreshold
    OBDVE
    again, it would be nice to include this info in the readme file, especially using plugin manager to finish setting things up.
    I hope you find my feedback useful
    Keep up the good work!
    Oops misread vehicle "information" for vehicle "odometer". Engine capacity and other settings not shown on the settings screen are not "yet" useful. They are there in case i need a fallback on some obd handling basically. Standalone and External GPS are one in the same and it allows you to assign a seperate GPS serial port for RRVM instead of depending on the gps data supplied by RR.
    And yes i need to add ALL the setting information in the readme. I will be sure to do that before the next build is posted. Thanks for your feedback.
    Live mp3Car Facebook Chat
  2. #522
    Woodbridge, VA
    Blog Entries
    43
    Version 3.1.6 updated. Improved support for international date formats. Should fix any issues with international users fuel logs, history, and updating vehicle scheduled maintenance. Also added settings description in the readme.
  3. #523
    Woodbridge, VA
    Blog Entries
    43
    Finally some progress on the scripting for vehicle tracker. A full days worth of warping my brain around PHP and Java and here we are. Still have a little bit of user account handling to do, and obviously a lot of css, but it should be available for registration soon.
  4. #524
    Apr 2012
    Question
    I'm new to RideRunner, and also for this plugin.
    Maybe it's my fault, but I can't understand this MPG calculation from the plugin.
    I've added these fuel data:
    Odometer____Price____Amount
    48800_______2_______60
    49700_______2_______60
    50600_______2_______60
    and in the attached image is what I see in the fuel log:
    If I do the math, I must obtain 15 MPG for each fuel item: 900 / 60 = 15
    Instead, it shows 66,67: maybe 60 / 900 * 1000 ?
    "Average miles per gallon" and "Estimated distance to empty" seems incorrect too.
    Can someone help me with this strange thing?
    Thanks!
  5. #525
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    providing some information might help.
    like which country are you from?
    I suspect a European one, not UK though, as you seem to have commas for decimal points.
  6. #526
    Apr 2012
    Quote Originally Posted by Enforcer View Post
    Yes, I'm from Italy, my operating system language is Italian (XP SP3), and I have to put comma instead of dot otherwise it was not recognized ( i.e. 1.234 -> 1234).
    If you need other information, I'll be glad to help.
    Thanks!
  7. #527
    Woodbridge, VA
    Blog Entries
    43
    What volume system does italy use, is it truly MPG or is it Liters per 100 km? If its the latter than the formula is like so:
    (FuelAdded 60 / DistanceDriven 900) * 1000 = 66.66~
    This was a formula given to me by a driver in australia.
    If italy uses MPG like the US then yes, the calculations are wrong. Basically i use the RR Variable $ISUNITS$ to declare whether or not to use MPG or L/100KM. Admittedly, it is a short cut that i need to fix, as I understand that the US is not the ONLY place that uses MPG.
  8. #528
    Apr 2012
    Quote Originally Posted by Sonicxtacy02 View Post
    In Italy we use liters per 100 km, or better, km per liter.
    By the way, the formula you use for liters/100km is wrong, because:
    FuelAdded 60 / DistanceDriven 900 gives you how many liters per 1 km, so to obtain how many liters per 100km you have to multiply by 100, not 1000.
    Way better is to divide DistanceDriven by FuelAdded to obtain km per liter.
    If you use variable ISUNITS, you may have another option to have km per liter.
    I can't find anything to set MPG or L/100km in the settings, or am I wrong?
    Thanks for your interest!
  1. Replies: 13
    Last Post: 05-28-2009, 03:18 PM
  2. Replies: 63
    Last Post: 03-10-2009, 07:49 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  5. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
