15/12/2010 20:40:41: Plugin Manager: loading Global Plugins...
15/12/2010 20:40:41: Plugin Manager: Plugin Found: MovieTimes plugin found but will be unable to create (most likely NOT registered)[skipped].
15/12/2010 20:40:41: Plugin Manager: Plugin Found: Mp3Art
15/12/2010 20:40:41: Plugin Manager: Plugin loaded (Global): Mp3Art
15/12/2010 20:40:41: Plugin Manager: Plugin Found: RRExtended plugin found but will be unable to create (most likely NOT registered)[skipped].
15/12/2010 20:40:41: Plugin Manager: Plugin Found: SkinTool
15/12/2010 20:40:41: Plugin Manager: Warning Plugin SkinTool does not support Enabled Method
15/12/2010 20:40:41: Plugin Manager: Plugin loaded (Global): SkinTool
15/12/2010 20:40:41: Plugin Manager: Plugin Found: Weather
15/12/2010 20:40:41: Plugin Manager: Plugin loaded (Global): Weather
15/12/2010 20:40:41: Plugin Manager: loading Global Plugins Completed.
15/12/2010 20:40:41: LoadSkin: C:\Program Files\RideRunner\Skins\CrystalBlue\
15/12/2010 20:40:41: Plugin Manager: loading SkinDir Plugins...
15/12/2010 20:40:41: Plugin Manager: loading SkinDir Plugins Completed.
15/12/2010 20:40:42: Plugin Manager: Warning loading mp3art (Attempt load more then once, most likely duped in globals and/or in skin).
15/12/2010 20:40:42: Plugin Manager: Error loading (menu.skin): Playlist (ActiveX component can't create object, check spelling of plugin, or its is COM registration missing.)
LinkBack URL
About LinkBacks
I thought your previous post was suggesting it was not working because i did not have .net installed, however i already do have it installed? 3 versions of it. Could it be a conflict having 3 versions of .net installed maybe?
