Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 72
Thread: RRec [Audio Capture]
  1. #11
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    mmm strange , i have HD tuner here so i also use linin , and i can record from the HD tuner, so its not what i thought it was going to be ,
    arh hang on your cmd is wrong
    RREC_FROM:LINEIN (your cmd )
    Right cmd is
    RREC_FROM;LINEIN
    Notice the ; in the cmd
    Hope this is it and works for you
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #12
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Quote Originally Posted by carputer1 View Post
    Right cmd is
    RREC_FROM;LINEIN
    Sorry, I put that wrong in the message. I had RRec_From;LineIn and ;Aux.
    Gee
  3. #13
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    open any skin that has a CL list in it , and in skintool put this cmd in and see what appears in the cl list
    RRec_Show_lines
    and also try
    RRec_Show_Devices
  4. #14
    Jan 2007
    DFW Area
    RRec_Show_lines
    and also try
    RRec_Show_Devices
    Carputer1,
    Sorry, I have responded back on this. I was real busy this weekend but we try it tonight. I will let you know.
    Thanks for helping
    Gee
  5. #15
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    if you still can't get it to work, find me at yahoo, ELCaminoJVC
  6. #16
    Jan 2007
    DFW Area
    Smile Working
    I got it working...
    I had to use RRec_From;Line for it to start recording. Notice, I could not use ;LineIn...not sure why but it is now working fine. I use the RRec_Status command as well and it changes from Ready to Recording.
    I was trying to use the SkinTool with the RRec_Show_Lines and _Devices and I did not get anything. I think I created a Custom list successfully but I did not see anything in the live log.
    Thanks for everyone's help
    Gee
  7. #17
    EL CAMINO's Avatar
    Jul 2005
    good to know, enjoy!
  8. #18
    Jan 2007
    DFW Area
    EL Camino...
    I am enjoying the plugin....I want to know what is the syntax to save the recorded files in another directory besides the default?
    I tried this...RRec_From;Line;RRec_Dir;D:\My Music\XM
    Thanks for your help
    Gee
  9. #19
    EL CAMINO's Avatar
    Jul 2005
    look in skin commands, under Variables, "RRec_Dir"
    Do This,
    Code:
    SetVar;RRec_Dir;D:\My Music\XM\
    this will change the path where the recording will be saved, and if you want to keep that setting saved, save it to skin.ini or rr.ini.
    Code:
    SetVar;RRec_Dir;D:\My Music\XM\||SaveToSkin;RRec_Dir;$RRec_Dir$
    or the easy way, will be, to just add the value to skin.ini
    Code:
    RRec_Dir=D:\My Music\XM\
  10. #20
    Nov 2004
    St Louis
    Been playing with this a little. I like what you've done so far. Comparing yours to my external command line program, from what I can tell, everything seems to be covered except commandline volume control, VU meters, and converting to MP3.
    Mine:
    Code:
    "FMREC","SETVARBYCODE;curtrack;FREQUENCE||SETVARBYCODE;SRDS;RDSTEXT||RUN;C:\Program Files\Recorder\Recorder.exe|-v:2-30 -q:s:22050 -s -f:"C:\Documents and Settings\Administrator\My Documents\My Music\New\Active Quarter\Last Month\This Month\ $curtrack$ $srds$.mp3" -c:05:00"
    YOURS:
    Code:
    "FMREC","SETVARBYCODE;curtrack;frequence||SETVARBYCODE;SRDS;RDSTEXT||SETVAR;RRec_Dir;$PLAYLISTDIR$New\Active Quarter\Last Month\This Month\||SETVAR;RRCEC_RQ;HIGH||SETVAR;RREC_CH;2||RREC_TMR;300||RRec_From;Silabs;$curtrack$ $SRDS$"
    While recording, does initiating the RRec_From command: close and save the file or abort the recording? Could you add a command so both options are available??
    Do you have a sample skin for RRec_Show_Devices and/or RRec_Show_Lines? Do you have a sample skin for all the variable/labels/indicators? This would help immensely with programming and allow me to visualize how to best fit this to my skins layouts.
    I love where this is going. I'm sitting here brainstorming how all this info could be used. I can envision RRec_Status indicator could be added to the header on every screen for constant monitoring. ONRREC_STS_CLICK is a brilliant idea that can be programmed to record using RR labels to create filenames. I could see ONRREC_STS_CLICK also initiating a popup menu upon buttonpress that shows the recording status as well as a separate screen callable say from the main menu that shows all the recording labels and variables. For example when calling the RRec screen manually, if no recording is currently ongoing a popup would say "Not Currently Recording," otherwise the screen would load. I could use that screen to monitor the status of the recording realtime, confirm the filename matches the expected variables, verify the recording settings are appropriate, etc., etc.
    Great Job, keep up the good work.
