Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 72
Thread: RRec [Audio Capture]
  1. #21
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    @ Giz i have most of rrec in Ranger working , along with show lines a devices, "Dictation Screen", and a popup on all radio screens to allow you to record feed, granted i don't have everything, but most in place.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #22
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Quote Originally Posted by EL CAMINO View Post
    look in skin commands, under Variables, "RRec_Dir"
    Do This,
    Code:
    SetVar;RRec_Dir;D:\My Music\XM\
    this will change the path where the recording will be saved, and if you want to keep that setting saved, save it to skin.ini or rr.ini.
    Code:
    SetVar;RRec_Dir;D:\My Music\XM\||SaveToSkin;RRec_Dir;$RRec_Dir$
    or the easy way, will be, to just add the value to skin.ini
    Code:
    RRec_Dir=D:\My Music\XM\
    EL CAMINO
    I tried this format for my button RRec_From;Line;MyXM;SetVar;RRec_Dir;D:\My Music\XM\
    and added this RRec_Dir=D:\My Music\XM\ to the skin.ini but for some reason, the file keeps being overwritten. The default method creates a new file each time.
    Anything I'm missing?
    Thanks for your help...
    Gee
  3. #23
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    ok, if you want to change the path, you need to set the new path first, then start recording, IF you dont have to use different paths, theres no need to keep setting the path every time you record something. like i said, just set the path in skin.ini or rr.ini, just do this.
    Keep this in skin.ini
    Code:
    Try this Code.
    Code:
    SetVarByCode;MyXm;TrackName||RRec_From;Line;$MyXm$
    the above code will use what ever RR is seeing as song title, and use that to name the recording.(dont have XM here but i think it will work)
    Code:
    RRec_From;Line
    the above code will record and name the files using the current date and time.
  4. #24
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    RRec error ?
    Hi guys,
    I tried this genial plugin, but i have that
    I had tried that:
    B,617,407,55,42,"RRec_From;Line",""
    B,617,407,55,42,"RRec_From;Mic",""
    But I have the same issue ?
  5. #25
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    have a look in your sound devices properties you may have it switch off, under record tab,
  6. #26
    May 2008
    Bordeaux, France
    I think that my devices are on , not shure but,!!!
    I upload my skin that i test .
    I run my skin with a button (load;rrec.skin). Is it ok ?
    Attached Files Attached Files
  7. #27
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    cmds are ok , but you have a pl list instead of a cl list , nothing will show up unless you use a CL list.
    do you actually have anything running in your line input socket, like XM or HD radio anything, if not connect your ipod to it or anything that produces sound you can use , this will make the line inout active.
  8. #28
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    okattached , i have updated your skin files all works here.
  9. #29
    EL CAMINO's Avatar
    Jul 2005
    adding a little more try this,
  10. #30
    EL CAMINO's Avatar
    Jul 2005
    Quote Originally Posted by GizmoQ View Post
    Been playing with this a little. I like what you've done so far. Comparing yours to my external command line program, from what I can tell, everything seems to be covered except commandline volume control, VU meters, and converting to MP3.
    Mine:
    Code:
    "FMREC","SETVARBYCODE;curtrack;FREQUENCE||SETVARBYCODE;SRDS;RDSTEXT||RUN;C:\Program Files\Recorder\Recorder.exe|-v:2-30 -q:s:22050 -s -f:"C:\Documents and Settings\Administrator\My Documents\My Music\New\Active Quarter\Last Month\This Month\ $curtrack$ $srds$.mp3" -c:05:00"
    YOURS:
    Code:
    "FMREC","SETVARBYCODE;curtrack;frequence||SETVARBYCODE;SRDS;RDSTEXT||SETVAR;RRec_Dir;$PLAYLISTDIR$New\Active Quarter\Last Month\This Month\||SETVAR;RRCEC_RQ;HIGH||SETVAR;RREC_CH;2||RREC_TMR;300||RRec_From;Silabs;$curtrack$ $SRDS$"
    While recording, does initiating the RRec_From command: close and save the file or abort the recording? Could you add a command so both options are available??
    Do you have a sample skin for RRec_Show_Devices and/or RRec_Show_Lines? Do you have a sample skin for all the variable/labels/indicators? This would help immensely with programming and allow me to visualize how to best fit this to my skins layouts.
    I love where this is going. I'm sitting here brainstorming how all this info could be used. I can envision RRec_Status indicator could be added to the header on every screen for constant monitoring. ONRREC_STS_CLICK is a brilliant idea that can be programmed to record using RR labels to create filenames. I could see ONRREC_STS_CLICK also initiating a popup menu upon buttonpress that shows the recording status as well as a separate screen callable say from the main menu that shows all the recording labels and variables. For example when calling the RRec screen manually, if no recording is currently ongoing a popup would say "Not Currently Recording," otherwise the screen would load. I could use that screen to monitor the status of the recording realtime, confirm the filename matches the expected variables, verify the recording settings are appropriate, etc., etc.
    Great Job, keep up the good work.
    will add those commands, also, there is no need to set the variables each time you need to record something, just save to skin.ini or rr.ini, in your case, rr.ini, i know you use different skins. in the posts above this one, you can find a skin file, for show devices/lines, with a simple line selector. SIlabs is Hardcoded, but you can find iit as "Radio Receiver". FYI i'm working in a new PI, that will eventually kill RRec, and some other of my PI's.
