Kewl, I'll keep my eye on this thread. Great job on this!
Printable View
i take it you have down loaded the attached from either me or El camino's posts
in El's skin file he has made it possiable to select (highlight) a line from the list ,so you can use it from the record button, if you have nothing connected to the line input, then you will not record anything, i also remember that the line input in sound devices on your computer is off by default, if useing vista or win 7 , could be the same for Mic, open your sound properties and look to see if this is the case. i know your French i'm UK
and i use a HD radio (Kindly supplyed) but only anolgue radio recieved .
here if need any more help
Again problem .
I had modified the skins files (just cosmetic) but recording don't run .
ok you have connected to socket but is it unmuted in sound devices ???
Whats your OS ????
in skin.ini RECLINE=Volume Principle not right, edit set to MIC for now leave the new button cmd alone , lets just get you working 1st.
Yes , the micro is unmuted effectively .
I try in Vista pro sp1. I just tried also in Virtualbox (xp sp2) , same issue.
I try now in a xp partition and give you the result .
If i understand well (I am french sorry), i change in skin.ini "RECLINE=Volume Principle" by
"RECLINE=MIC" and try again ?
also can you check for this dll in
Windows/system32 folder your looking for lame_enc.dll
just making sure everything got installed correctly
its starting to sound like a hardware issue more than anything , i'm playing with this in demark at the moment , thought it my be a Langage problem but dose not look that way,
you have pm
