Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 72
Thread: RRec [Audio Capture]
  1. #61
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    tek x has only just been released in the skin in progress thread, and el is right , when you open tek x you need to press & hold 1 of the menu buttons , and select the rrec button,
  2. #62
    Jul 2009
    B.C., Canada
    Ok, I see it. Teknik-X. I'll try it when I get home tonight.
  3. #63
    Jul 2009
    B.C., Canada
    No dice, says the same thing. "!Error! Couldn't select device". Maybe a Windows 7 thing?
  4. #64
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    yea looks like it.
  5. #65
    Jul 2009
    B.C., Canada
    Is there going to be any progress on making that work? I'll help test if you need me to.
  6. #66
    EL CAMINO's Avatar
    Jul 2005
    after some project's i'm working on, i'll see if i can do something about it.
  7. #67
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Quote Originally Posted by EL CAMINO View Post
    El Camino,
    Any update on this plugin working with Windows 7? It was working perfectly in WinXP Pro but Windows 7 gives the error mention in the above post.
    Thanks for looking into this.
    Gee
  8. #68
    EL CAMINO's Avatar
    Jul 2005
    i havent had time to look at it, sorry, i being working on my BASS PI, FYI, i have plans to add RRec functions to BASS.
  9. #69
    Jul 2009
    B.C., Canada
    If you have Mitch's Sirius adapter it came with a program to record Sirius and XM. You can embed it into RR, or, if you're talented enough make an RR plugin that'll use that program to record. I can't remember the name but it's available for free download too. If I remember I can get the name tonight. That's what I'm using until RRec works for Win 7.
    If you pay for the plugin package you can also set it to send you a notice when a song comes on and automatically record it for you but I haven't bothered with that as I'm eventually going to try and make my own RR plugin to do that (not the record part, just the memo) but don't hold your breath.
    EDIT: It's called SX Recorder. The only downside is it doesn't record the entire song if you hit record half way though.
    PROGRESS:
    Hardware: 100%
    Software: 99% - Always upgrading and improving.
    Installation: 100%
    WORKLOG:
    2005 F-150
  10. #70
    Jan 2007
    DFW Area
    Stop Working
    I had this working great in Windows XP and then I upgraded to Windows 7 but I went back to Windows XP. I kept the same settings I had before and now I can't get this to work. I am getting this error "!Error! Couldn't select device" and !Error! Couldn't initate the encoder. So, I loaded up the Teknik X skin to see my devices/show lines and it shows Line Volume, Mic Volume, etc. and I see Realtek HD Audit Input but when I hit record, nothing happens.
    Any sugguestions?
    RR Aug. Release
    DFX 4 and Teknik-X
    WinXP Pro
    Gee
