Page 1 of 8 12345678 LastLast
Results 1 to 10 of 72
Thread: RRec [Audio Capture]
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    This PI is intended for NON COMMERCIAL USE ONLY..... you know the rest... AND you know i'm talking to you...
    if you are getting any compensation using my PI you are NOT allowed to redistribute or support this PI..
    as the name says, this plugin was created as a simple wave in recorder, is very simple but handy, can record from almost any wave in. like Mic, line in etc. and saves as mp3, also picks up silabs/ads radio receivers. i been testing it and seems to be stable enough, so here it is for any one who needs something like this little guy. i included some skin files for testing, "radio_player", i use Silabs, so is based in this function. for more details in how to use it please read Skin Commands.txt. enjoy.
    Get it from Here.
    THIS PI IS NO LONGER SUPPORTED, A MUCH BETTER VERSION IS PART OF BASSRR, FOUND HERE
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Nice 1 finally finished it , now i have to update my skin for it now and finish it off lol,,, why could'nt you finish it before i released lol....
    so far nice job
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    COOL! I can finally stop holding my phone's voice recorder up to the speakers when a song I like is on the radio and I don't know who the artist is.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    EL CAMINO's Avatar
    Jul 2005
    that's the main reason for creating this, record radio. and with some simple tricks you can name the files using RDSTEXT.
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Great job, going to give this a try..
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Quote Originally Posted by EL CAMINO View Post
    NOTE:
    2 options available.
    an installer(thanks mitch), all is copied, and registered.
    and binary,the easy way.
    I am trying this plugin out but when I click a button to start recording; nothing happens. I am trying to record linein (xm radio is on this line).
    I used the installer, added a button with "RRec_From;LineIn" but I don't see a window come up or see anything in the default directory specified. What I am missing?
    Thanks for your help
    Gee
    EL CAMINO's Avatar
    Jul 2005
    if you didnt see an error screen that means you did record something, the default directory is something like this..
    C:\Documents and Settings\Administrator\My Documents\RideRunner\Plugins\RRec
    you can change/View this setting, using "RRec_Dir" variable, all this is explained in Skin Commands.txt. A good way to know whats going on, is using the labels, like "RRec_Time"
    or "RRec_Status", if you don't want to create a screen yet, use SkinTool to debug.
    but if you still have issues let me know.
    Jan 2007
    DFW Area
    I looked in that directory and did not see anything. Also, I used the variable (RRec_Time) to see what was going on but the time did not start. So, I will try the skintool (i never used it before). It is suppose to use windows sound recorder or something?
    Thanks for your help.
    Gee
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    double check these items for us please.
    open system32 folder , look for lame_enc.dll
    open rr debug , check to see if the rrec is loaded and running,
    are you useing the test skin file that came with the plugin,
    answer these basics then we can go from there,
    this work great in my skin ,
    Jan 2007
    DFW Area
    Update
    Quote Originally Posted by carputer1 View Post
    Response: I found this file and winmm.dll in the dir.
    Response: It's loaded and shows running - no errors.
    Response: I tried the skin and same thing. See my comments below
    First of all, thanks for helping on this.
    To answer your questions (see above)
    I got it working but only with RRec_From;Mic. So, it works but when I tried RRec_From;LineIn or RRec_From;Aux, the popup window came up and stated "Error -Can't open device LineIn....Aux". The Mic option worked fine and I saw the saved file in the directory.
    So, in windows, I have these options for Recording ---Recording, LineIn, Mic and StereoMix. I have only a mute option and not select. Yes, it is unmuted and the volume is up. What else should I look for or set here?
    Edit: I have my XM (tuner) and HD (tuner) both connected through LineIn connection on the motherboard. I am not using the line-in plugin option in RRconfig. I hope this helps some.
    Gee
