Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
Thread: Laptop Shutdown Controller - FINAL - 24OCT09
  1. #31
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Hi Thunderstick. Trying to make it work with my Tablet using Windows 7. It works perfectly, but when it reboots using battery, I'm getting the autoit error described above. Any solution to that?
    If I start it on ac power, the program runs fine after booting.
    Thanks.
  2. #32
    Jun 2010
    Great software but...
    How do I get my laptop to come back out of standby when I turn my ignition back on? Windows xp will auto standby or hibernate by itself without ant extra software when ac power is cut, problem is trying to get the laptop to auto come out of standby, any idea's for that?
  3. #33
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by RipplingHurst View Post
    Thanks.
    He needs this at the of his autoit script:
    Opt("MustDeclareVars", 1)
    Which basically will mean that he is just using vars w/o declaring it first and if its not previously used when called on, is when you end up with this message.
    Doing proper coding, means you declare all variable before you use them, else.....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #34
    Feb 2011
    Perth, Australia
    Sorry for the dumb newbie question, but where do I download the laptop shutdown exe?
  5. #35
    Feb 2011
    Perth, Australia
    Quote Originally Posted by lawabb View Post
    To answer my own post. I think this may be the same thing...correct me if I'm wrong. Oh well I'll give it a shot for 5 bucks.
    http://store.payloadz.com/details/77...ontroller.html
  6. #36
    Feb 2011
    Perth, Australia
    Well it sure shutsdown. Turn off power - laptop starts shutting down. But now riderunner doesn't resume. Solutions?
  7. #37
    Feb 2011
    Perth, Australia
    Some info
    RR_with_shutdown_0.2.py.txt
    Oh well, I guess this thread is old, and the code has vanished, and I'm talking to myself, but I've had a go at doing what I need with a python script. Its a hack, but works for me, use at your own peril.
    Attached file should have a .py extension.
    Edit the file, to suit your requirements, with a code editor such as scite or notepad.
    Edit: Seems the attachments on other posts have appeared again. Seems like I picked good time to visit this site!
    Edit: Updated to version 0.2 so that power must be off for a defined period of time before shutdown commences. This should avoid shutting down on momentarty power interuptions such as caused by engine cranking etc
  1. Shutdown controller
    By screwc149 in forum Power Supplies
    Last Post: 11-22-2006, 10:38 AM
  2. Shutdown/Startup Controller for laptop
    By JoyRidun in forum General Hardware Discussion
    Last Post: 07-01-2004, 06:08 PM
  3. Shutdown controller - New Version
    By weekendowel in forum Power Supplies
    Last Post: 06-10-2004, 12:28 AM
  4. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 01:33 PM
  5. why use a shutdown controller???
    By cyjad in forum Newbie
    Last Post: 12-04-2003, 04:49 AM
