You could use an unpacker like innounp, the Inno Setup Unpacker http://innounp.sourceforge.net/
Thanks for the plugin!
Well if I had a scrap machine set up I would, but I don't at the moment.
Besides afetr using Carputer1's skin installer which has caused all my lists to become Italicised I am wary of using installers now.
I prefer to know exactly what is being installed, where it's installed and what changes are being made. The I can make the choice on whether to install it or not.
As for virtual machines, tried that, find them too slow for what I want, need to set up a really big power rig, but never around to doing that.
i may be going OTT , as video while driving is mostly Illegal ,in most countrys,
i think either skinners should release this with thier skins default , or rr releases as default, and its down to the user to de-activate, at least the authors of skins or rr are covered. and done thier bit.
its not like its hard to de-activate is it now
Riderunner / Genesis
Wifiman_NET:Version 1.0.0
Exactely that i wanted .
Thanks Blue . You are the Best...
I have a motionlock,I have a motionlock
Ihave a motionlock
Looks like I'll have to pull out my Vista VM then and take a look....
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
This is EXACTLY what I have done with the DFX skins in the past. I enable it by default, it is up to the user to deactivate it. I personally want to think that I had nothing whatsoever to do if someone was watching video in the car and got either a ticket, or God forbid, into an accident.
And on top of that, in this day and age, I do not want to be open for a lawsuit.![]()
My Fiero Build Thread
Hi Blue,
I try gpslockout in xp (tried also in vista) who don't run .
The .ini file must to be on rr path like motionlock or in gpslockout folder ?
It is well loaded but when i use my video_player . I see my video .
i upload my debug file .
thanks
Post your GpsLockout.ini file as well.
Code:############################################################################################### # # Settings Explained: # # Speed --------------- the max speed consider as 'stationary' - anything over that and access # to the configured commands/skins is blocked # cmds --------------- a list of commands to block while moving, space seperated # skins --------------- a list of skins to block, space seperated again # DisableScreen ------- the screen to call when above speed limit setting # # * To test, set speed to -1 # ################################################################################################ [Settings] Speed=3 cmds=dvd video skins=external_DVD.skin video_player.skin windvd_player.skin DisableScreen=gpslockout_denied.skin
