4 Attachment(s)
GpsLockout [ UPDATED 11/12/09 ]
RideRunner Extension Plugin for GpsLockout
General
This is a replacement for the old outdated MotionLock plugin by festy. If you used
the motionlock and changed the default settings then you'll need to transfer them
over to the GpsLockout.ini. There are no 'Mode' or 'DisableScreen' settings.
There are some additional notes for the settings at top of the ini file.
Labels
"GpsLockout_Engaged" - Shows 'Disabled'\'Enabled' depending on GPS speed is above/below
the 'stationary' imit
Indicators
"GpsLockout" - Indicates that the Plugin is Running
"GpsLockout_Engaged" - Indicates that video screens\cmds are locked out
Events
"GpsLockout_ONMotion" - is fired in place of the original issued command if already in motion(moving)
or if on a locked screen when starting to move, will close it then issue event
Included* in the Screens folder is an example screen that you can use. To use, just
copy the files from there into the skin folder that your using.
* screens are from festy's MotionLock plugin
I've added the screens from the carwings skin that were edited by pierrotm777 below.
