Questions and Requests
Q1. Does this use the same screens and commands as festys.
Q2. Why did you stick this in the wrong forum?
R1. Can you (and I will ask this of other plugin authors) also release it in a non installer version.
RideRunner Extension Plugin for GpsLockout
General
This is a replacement for the old outdated MotionLock plugin by festy. If you used
the motionlock and changed the default settings then you'll need to transfer them
over to the GpsLockout.ini. There are no 'Mode' or 'DisableScreen' settings.
There are some additional notes for the settings at top of the ini file.
Labels
"GpsLockout_Engaged" - Shows 'Disabled'\'Enabled' depending on GPS speed is above/below
the 'stationary' imit
Indicators
"GpsLockout" - Indicates that the Plugin is Running
"GpsLockout_Engaged" - Indicates that video screens\cmds are locked out
Events
"GpsLockout_ONMotion" - is fired in place of the original issued command if already in motion(moving)
or if on a locked screen when starting to move, will close it then issue event
Included* in the Screens folder is an example screen that you can use. To use, just
copy the files from there into the skin folder that your using.
* screens are from festy's MotionLock plugin
I've added the screens from the carwings skin that were edited by pierrotm777 below.
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
All done via the ini file, just like festy's.Q1. Does this use the same screens and commands as festys.
Er um..b/c it cant be posted in the released one, Duh I'm not a mod!Q2. Why did you stick this in the wrong forum?
No, this is the way that PI's are supposed to be released in.R1. Can you (and I will ask this of other plugin authors) also release it in a non installer version.
Now i'll answer your req with a req...
That NO plugin authors put make users go thru another forum just to DL it!![]()
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
My Fiero Build Thread
It is a VERY simple installer, that just copies the files to [Your RR folder]\Plugins\GPS Lockout. The only skin needed is "gpslockout_denied.skin" or what ever you want to call it actually, as it's set in the ini file. So, yes, you can use the existing skin from Festy's plugin, and nothing is then needed to be skinned if you have that skin in place already.
The list of skins that are not aloud are set in the .ini file:
# Settings Explained:
# Speed --------------- the max speed consider as 'stationary' - anything over that and access
# to the configured commands/skins is blocked
# cmds --------------- a list of commands to block while moving, space seperated
# skins --------------- a list of skins to block, space seperated again
# DisableScreen ------- the screen to call when above speed limit setting
# * To test, set speed to -1
[Settings]
Speed=3
cmds=dvd video
skins=external_DVD.skin video_player.skin windvd_player.skin
DisableScreen=gpslockout_denied.skin
Probably b/c you SUPPOSED to be doing work, not playing!(New PC's at work and I don't have local admin rights. First time EVER )![]()
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
enforcer, install it on another machine... then u can do what u need to do...
its also handy to have virtual machines
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
