1st release
Let me know what you think?...
1st release
well i have dl'ed and played , very nice work thunder , i know what i'm going to use it for , will let you know if i come across anything ,
CPU here for me is not a problem useing your script , yes it dose increase when dragging but not hit higher than 40% so far , with rr running and garmin, and music playing.
Thanks,
I did find a bug last night. When using the autopopup feature it doesnt return after the timer times out. Problem solved.
I also found problems with Speed Zone interfacing correctly. I fixed this as well and also added a label to speedzone so that it would update and display the correct information needed.
I try to use the flymenu, and i don't know where is my error .
To run the menu, i have tried these commands:
"MyApp53","flytomenu.exe sliderMENU.skin"
or
"MyApp53","run;flytomenu.exe sliderMENU.skin"
or
"MyApp53","run;$skinpath$flytomenu.exe sliderMENU.skin"
The menu don't appear .
Thanks for your help .
add a bar to the line then it will work , and the path to the exe
"MyApp53","RUNQ;$SKINPATH$flytomenu.exe|sliderMENU.skin"
taking that the exe is in your skin path
Question regarding overlay plugin....can one put flash objects on the overlay?
Basically would like a static overlay with all my flash buttons ...it never changes from screen to screen and I would not need for it to move or hide...if i could overlay the buttons it would save alot of resources for me!! Now, every skin has to reload and duplicate the same old buttons...!! pita!!
thx...oh, and great work here!!
No this wont work with flash. Because of the way that the menu's are created, I dont think flash is a possibility.
