Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
Thread: [Final Release Candidate] Overlay Menu - Dragable, Moveable, Flyable, Commandable
  1. #31
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Quote Originally Posted by olevelo View Post
    I'm having trouble with exiting a screen. I simply changed me elcosmenu references to flytomenu and it opens ok, but when I exit the screen exits but garmin stays open...if I close garmin I have a blank screen remaining (using a clear background). The setup is similiar to the carwings garmin screen. Is there a different command for exiting?
    Also, any chance of adding indicators or text alignment?
    Not really sure why this doesnt work, all it does is send the command to RR, which is all elcosmenu does this part of the code is basically the same.
    Sounds like an RR issue or something else. Not sure....
    New Age Garmin - Skin for RR
  2. #32
    Oct 2009
    On the skin button I'm using "X_OVERLAY;Exit" with X_OVERLAY defined as "SendMsg;FlyToMenu;Exit" I believe...it works fine as ElcosMenu but not when I simply change to FlyToMenu.
  3. #33
    Oct 2009
    Also I'm unable to send any update messages to update song title or time or anything. It worked fine with "SENDMSG;ElcosMenu;update", but I can't get any combination to work. I also tried various combinations of X_OVERLAY||WAIT;1||Exit, changing X_OVERLAY to just "Exit", everything I could think of. If I "exit" in the skin, it exits flytomenu, while if I use the exit in exectbl, it exits garmin and the underlying skin, but flytomenu stays open! And since the "sendmsg" doesn't seem to work, I can't get it to close.
  4. #34
    Aug 2006
    West Allis, WI
    edit
  5. #35
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    May be , just ESC command who run well.
  6. #36
    May 2008
    Bordeaux, France
    I created a menu for your plugin.
    I should like to have the time on the bottom bar.
    Is it possible to add that:
    Code:
    L,76,562,50,24,255,255,255,14,"Arial","VOLUME",,,"DS=2,2,0,0,0"
    L,690,561,92,23,255,255,255,16,"Arial","TIME",,,"DS=2,2,0,0,0"
    or
    Code:
    If i try, that the label are not updated !
    INC are possible ? (img or .skin)
    May 2008
    Bordeaux, France
    Smile
    Hi ThunderStick,
    I have some issue with your plugin.
    As you can to see, the texts are not centered and the police's size is not good.
    The text is always positioned on the left side and smaller than the RR size.
    I should like to have off,on and down png files .
    This is my screen code that i should like to use !
    Code:
    RoadRunner Skin
    RRScreen GoogleAddress
    GoogleAddress_off.png,GoogleAddress_off.png,GoogleAddress_on.png,GoogleAddress_down.png
    [Labels]
    L,682,37,91,30,255,255,255,18,"Arial:B","=Lat/Lon","center",,"DS=2,2,0,0,0"
    L,681,105,91,30,255,255,255,18,"Arial:B","=Exit","center",,"DS=2,2,0,0,0"
    L,439,35,202,30,255,255,0,23,"Arial:B","=$TOLONGITUDE$","left",,"DS=2,2,0,0,0"
    L,105,35,202,30,255,255,0,23,"Arial:B","=$TOLATITUDE$","left",,"DS=2,2,0,0,0"
    L,30,100,608,30,255,255,0,23,"Arial:B","=$ADDRESS$","left",,"DS=2,2,0,0,0"
    L,67,160,50,24,255,255,255,14,"Arial","VOLUME",,,"DS=2,2,0,0,0"
    L,690,160,92,23,255,255,255,16,"Arial","TIME",,,"DS=2,2,0,0,0"
    [Buttons]
    B01,30,109,612,30,"OSKTOCMD;ADDRESS;SENDMSG;GoogleTraffic;ADDRESS",
    B02,104,38,202,30,"OSKTOCMD;TOLATITUDE;SENDMSG;GoogleTraffic;TOLATITUDE",
    B03,439,38,202,30,"OSKTOCMD;TOLONGITUDE;SENDMSG;GoogleTraffic;TOLONGITUDE",
    B04,594,155,92,35,"SENDMSG;GoogleTraffic;RESET",
    B05,655,98,140,44,"ESC",
    B05,655,31,140,44,"SENDMSG;GoogleTraffic;COORDINATES",
    B02,652,29,140,44,DRAGITDOWN,
    /DRAGIT-ANYWHERE
    /POSX,0
    /POSY,400
    /DRAGIT-BOTTOMMAX,585
    /DRAGIT-TOPMAX,400
    /DRAGIT-LEFTMAX,0
    /DRAGIT-RIGHTMAX,0
    /AUTOPOPUP,YES
    /AUTOPOPUPCMD,FlyIt
    /AUTOPOPUPXPOS,0
    /AUTOPOPUPYPOS,545
    /AUTOPOPUPTIMER,5
    END
    The time and the date are never updated, only if i exit and rerun the overlay menu.
    ElcosMenu had an "SENDMSG;ElcosMenu;update" command. I had tried "SENDMSG;FlytoMenu;update" that don't run !
    Nota:
    ,,"DS=2,2,0,0,0" command are not understood, but it is not really a problem.
    A new version is possible ?
    Thanks for your help !
  8. #38
    Oct 2010
    Canada
    Hey guys. Having some issues with flytomenu button commands. I want to have a button on the menu load a new skin and at the same time, close the flytomenu so that it doesn's show up on the new skin. For some reason it appears that when you put a button in the flytomenu skin, you can only program it to do one thing. I can set it to EXIT (which effectively closes the flytomenu), but if I try something like:
    B,x,x,x,x,"EXIT||Weather"
    instead of closing the flytomenu and loading the weather skin, it just closes the flytomenu. It ignores the second command. If I were to switch the order of the commands above, the weather skin still doesn't load, and the flytomenu exits. As another option, instead of using the "weather" command, I've also for example tried creating a "Weatherload" command that I've put in the exectbl programmed to "Weather||EXIT" . Doing this, I can get the weather skin to load correctly, but then it exits the weather skin and goes back to the previous skin instead of exiting the flytomenu.
    Just wondering if anyone has any ideas as to how i could get a button on my flytomenu skin to execute an RR command and exit the menu at the same time.
  9. #39
    May 2008
    Bordeaux, France
    Try this version !
    Elcosmenu2
  10. #40
    Oct 2010
    Canada
    Solution
    I've found a method that works for allowing a button in the slidermenu.skin to execute a command and close the menu simultaneously.
    Program a button in the slidermenu.skin to execute a custom command
    ie. "WeatherShortcut"
    Then, in the ExecTBL, define the command as:
    "WeatherShortcut","WEATHER||CLOSEWINDOW;FlytoM enu"
    This works to open the weather skin and close the flytomenu so it's not overlying the weather skin.
  1. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
