Results 11 to 20 of 23
Thread: RRPointer...
  1. #11
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Should have kept the with the RR std as far as color syntax is concerened.. eg RGB not BGR
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #12
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Wow, this is WAY cool! No more need for flash gauges, and the fact that you can overlap gauges is a MAJOR plus. With the flash gauges they take up the entire square where they are located, and thus cut off other graphics and labels ect. Nice work!
    My Fiero Build Thread
  3. #13
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    Can't, a standard picturebox in VB only accepts it in HEX, That is the reason it is inverted...Look it up...
    Of course I could have done the invert from RR's ascii to hex, just more code.
    Yep, you can overlap some, Then Lock the pointers and they will stay that way. You can't put a pointer directly on another, cause one will fall under the other...A limitation of the picturebox again...
    Just remember the pointer is the only active area, the rest of the "box" is click thru...
    ...JJG
  4. #14
    Dec 2007
    Washington, USA
    The only thing I havn't tested yet is sending the pointer a steady stream of updates...such as a tach input, GPS Speed, ect...
    I could whip up a test harness app, but,
    If someone has that ability, could I get you to report on your findings?
    ...JJG
  5. #15
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    Quote Originally Posted by Jebus View Post
    ...JJG
    I'll see about giving it a go tonight/tomorrow and test it out tomorrow/saturday
    Yay day off tomorrow!!
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  6. #16
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by Enforcer View Post
    If you knew who I worked for . . . . .
    Putting pipes up peoples Bottoms to be flushed out lol.....
  7. #17
    Oct 2008
    Ontario, Canada
    okay, maybe I'm missing something here Jebus, but how would you create a gauge for say the CPU?
    How would this grab that value? Where would you put the 'CPU' label?
  8. #18
    Dec 2007
    Washington, USA
    Here's how it is set up now, If you can set a variable you can set the pointers...
    setvar;myevent0;75||rrpointupdate;0;$myevent0$
    setvar;myevent1;4055||rrpointupdate;1;$myevent1$
    setvar;myevent0;0||rrpointupdate;0;$myevent0$
    setvar;myevent1;0||rrpointupdate;1;$myevent1$
    I'm workin on it this weekend a bit, I'll post an update soon...
    ...JJG
  9. #19
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    I think this is (way) cool but what if you are ignorant to coding, can I flood this thread with a lot of questions and risk being flamed?
    If you cant DODGE em, RAM em.
  10. #20
    Dec 2007
    Washington, USA
    If that is the case, maybe RideRunner isn't for you...
    This is not plug and play...You should get familar with RideRunner and skins before you tackle this.
    ...JJG
