Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: RRPointer...
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    RRPointer...
    /RRPointer.dll Version 1.0.0.0 Beta...
    /Developed for a MegaSquirt installation in my 68 Bronco...
    /Drop all but the skin files into $PluginsPath$RRPointer...
    /Register using the batch file...
    /Drop pointer.skin, Pointer_On.png, Pointer_Off.png into your skin of choice...DFX?
    /Currently set for 800 x 600, This will be configurable...
    /Only 6 pointers right now...0 thru 5
    /Pointers are fully configurable...
    /0 is index of pointer, 60 is value to update
    rrpointupdate;0;60
    rrpointupdate;5;120
    /show/hide individual pointers
    rrpointhand;2;true
    rrpointhand;3;false
    /lock/unlock pointer position
    rrpointlock;true
    rrpointlock;false
    /show/hide all pointers
    rrpointshow;true
    rrpointshow;false
    /refresh after an ini change
    rrpointrefresh
    /Use this to load RRPointer in exectbl.ini from a button...or ? SetInd turns on the gauge graphics in the skin...
    "Load;Pointer.skin||rrpointshow;true||SETIND;!Tach o;On||SETIND;!Speedo;On"
    /The pointer.skin will hide RRPointer upon exit. Look at the pointer.skin file...
    rrpointshow;false
    /Call rrpointlock;false to unlock all the pointer positions...
    /Grab the Pointer at the pointer center to move the pointer position...
    /Then call rrpointlock;true to lock all the pointer positions...
    /Call rrpointhand;2;true to show pointer 2, ect...
    /Call rrpointhand;2;false to hide pointer 2, ect...
    /Load the pointer screen and give it some update value's...
    /Look at the RRPointer.ini file to see how to configure colors, size, length of pointer, ect...
    /Notice the click thru anywhere but the pointer...
    /Hover over the pointer center to identify each pointer, 0 thru 5
    /Many more commands coming soon!
    /...JJG
    Attached Files Attached Files
    Dec 2007
    Washington, USA
    RRPointer.ini settings....
    [SETTINGS]
    # Show Pointers
    pShow=False
    # Max Pointers, zero based to five = 6
    pCount=5
    #lock/unlock pointer position
    pLock=False
    #debug
    pDebug=True
    # Pointers....
    [POINTER0]
    #Top and Left position of pointer, Auto set when pointer is positioned on screen.
    pTop=182
    pLeft=34
    Pointer visible True/False
    pVisible=True
    #Style of gauge, 1 is round, 2 is half round
    pStyle=1
    #Min and Max of your gauge face, resolution
    pMinUnit=0
    pMaxUnit=110
    #Min and max of pointer position, o to 60 degrees, like a clock
    pMinFace=7
    pMaxFace=53
    #Needle or hand width
    pHandWidth=3
    #Needle or hand color, must be hex, BGR
    pHandColor=&H0000FF
    #Needle or hand length, from outer edge of arc, 0.0 or 0.1 is a good length
    pHandLength=0.0
    #Center circle diameter in pixels x 2
    pCircle=10
    #Center circle color, must be hex, BGR
    pCircleColor=&HFF0000
    #Value to set pointer at, Auto saved here
    pValue=90
    #width and height of pointer arc, should be equal
    pScaleWidth=300
    pScaleHeight=300
    [POINTER1]
    ...JJG
    Dec 2007
    Washington, USA
    ...Reserved
    Dec 2007
    Washington, USA
    Bump...
    Wow, I thought that this would fly like an eagle...
    Maybe I didn't explain it well enough...
    This is a native RR plugin that gives you the ability to create LCD Analog GAUGES for your vehicle, with any input source, OBD, Fusion Brain, VSS Speedo sensor, Tach input, anything that needs a gauge on screen. You can use any gauge graphic that you want, on any screen that you want, at any screen position that you want...
    This is all acomplished WITHOUT FLASH. It uses very little CPU time.
    The Pointers are fully configurable, and moveable onscreen at run time. They can be locked into position after placement.
    I havn't seen anything like this for RR until now. All the guages I have seen here are Flash based. This is pure VB, just like RR...
    ...JJG
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    very cool.
    Yes, I didn't get it until further explanation was offered.
    Very cool.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I got ir, but think the name doesn't really give people the right idea.
    RRAnalGauge though would probably give totally the wrong idea.
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    yea, I was thinking it would create actual mouse pointers, though then seeing the pictures figured it was gauge related (not anal gauges)
    I'll be giving this a try soon, it would make customizations a little easier not having to create flash. And it seems like you could have some gauges overlapping a bit, no?
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
    Dec 2007
    Washington, USA
    Due to a lack of clicking of the google ads on my site by downloaders updates to skins and plugins will be delayed
    Hey E,
    I think its hilarious that you came up with RRAnalGauge...
    ...JJG
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Jebus View Post
    Hey E,
    ...JJG
    If you knew who I worked for . . . . .
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Hell, those screens would fell like home in my car.. Correct Make & Color!
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
